Brake/Clutch Fluid Flush & Radiator Flush
MacAttack7
2011 Mazda2 Sport (Manual)
Would it be a good idea to get a brake/clutch fluid flush & a radiator flush?
Dealership said $125 for the brake flush, $129 for the radiator flush.
I just hit 50,000 miles & was thinking of getting them both done.
Then I was going to change the spark plugs which I can do myself.
I have a Mazda2 by the way, but that forum isn't too active.
Thanks.
Are you sure you need spark plugs at only 50,000 miles?
The brake fluid should be flushed every 30,000 miles, so if you haven't had it done, I suggest you do. Most newer vehicles can go 50,000 miles before needing a coolant drain and fill. You don't need a coolant "flush" unless you waited far longer a time period than what is listed in the manual. So if the manual calls for a coolant change at 40,000 - 50,000 miles, just have them do a drain and fill. They should charge less than $50 or so.
Latest posts
