CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 4 of 4
Thread: Startup issue, Idle issue, running issue (all related)
  1. #1
    Registered Member Keatonc's Avatar
    2001 Mazda Protege MP3
    Join Date
    Sep 2012
    Location
    United States
    Posts
    69
    I bought another mp3 from someone who rebuilt the engine. Strangest thing happens, when the car is started, it continually rev's up to redline unless put into gear. After I unplugged the IAC, the car idles around 2500 with a shaky idle. I removed the egr, cleaned, and kept the solenoid off as well. I cannot for the life of me figure out the problem. Im betting its the IAC but im not sure how to test it. Also, what should the throttle position be set at for idle? as the throttle is slightly angled open when depressed
  2. #2
    Join Date
    Sep 2012
    Location
    United States
    Posts
    69
    Just did some more work on it, IAC seems to work fine, I messed with the AAS screw and nothing changed. Also, the short term fuel trim from the second o2 sensor is 99.5% and the timing advance for cylinder #1 is up to 63.5 degrees once it reaches idle at 6-6500 RPM. There arent any vacuum leaks that I can tell. Would a mis-adjusted camshaft cause this? even if off by one tooth?
  3. #3
    Registered Member kms1990's Avatar
    2011 mazda 3 hatchback GT
    Join Date
    Jun 2013
    Location
    Fort Worth, TX
    Posts
    932
    yes that sounds like either the timing is off or the throttlebody/ iac is failing but sounds more like a timing issue
    Disturbed "is she not right, is she insane?"
  4. #4
    Join Date
    Sep 2012
    Location
    United States
    Posts
    69
    If anyone is wondering, I finished the car. Ended up replacing the entire intake manifold, which was the wrong manifold for the ECU setup, apparently the different manifolds can cause this issue.
Similar Threads
  1. Idle Issue
    By thomjs1 in forum Mazdaspeed Protege
    Last Post: 12-21-2013, 02:48 PM
  2. Replies: 2
    Last Post: 09-20-2013, 12:56 PM
  3. idle issue...still; please help
    By brett02 in forum Protege5
    Last Post: 10-09-2009, 12:30 PM
  4. 90 Grand Prix issue... gauge cluster issue
    By StealthWyvern in forum Lounge
    Last Post: 02-14-2009, 09:43 PM
  5. Idle issue
    By DeadGeneration in forum Protege5
    Last Post: 08-19-2005, 10:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
