07. 6i 2.3L Motor Blow by, Which years are capable for motor swap?
LonkusAE
07 mazda 6i 2.3L Auto
Yesterday on my way to work, My car started acting up. giving loud noises from the engine. Limped it in to the work parking lot. I left the car running and took off the oil cap and got sprayed in the face with oil. Motor needs heavy work I am assuming since its loading up so heavy. Instead of doing a rebuild and spending loads of money on it. I have found a couple different motors. Both of which are from an 08 2.3L. Is everything between these two pretty much just a straight swap as far as wiring and bolt placement compatible?
I have also seen that the Fusion 2.3L is an identical motor to the car but it didn't give me enough details to truly know myself. The replacement motor (s) that I have found are $1400 (120k miles) and 1500 (112K) miles. Is there also anything that I need to absolutely verify when picking up the used motor other then compression test's and obvious defects / cracks/ and so forth?
Any and all help would be greatly appreciated.
Thank you,
