CorkSport.com is MAZDA PERFORMANCE!
Page 8 of 8 FirstFirst ... 678
Results 106 to 114 of 114
Thread: My "follow-along" Mazda5 Suspension upgrade
  1. #106
    Registered Member Moe Drama's Avatar
    Mazda 5 GT 2009
    Join Date
    Sep 2013
    Location
    Winnipeg MB Canada
    Posts
    21
    Quote Originally Posted by Secondtyme View Post
    Were your lateral links sitting cock-eyed in the mounting tabs like this l/l or were they vertical between the tabs lke this l l l ? If they were sitting crooked i would go ahead and replace them, you dont want to have to tear it all apart again right? Snow, in springtime, stupid damn global warming...
    when i replaced my rear shocks I noticed that link "|/|" issue you mentioned. If I'm trying to eliminate a clunk should i be going whole hog like the OP? Are there parts and bushings out there that will last longer than OE?
  2. #107
    Registered Member Dave88LX's Avatar
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Haha no not a Honda forum. General automotive. Smart guys generally, not sure what their issue is.
  3. #108
    Registered Member Silentnoise713's Avatar
    2008 Mazda5 Grand Touring; 2009 Honda Fit Sport/Nav MT
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    The language in their response show they are young or immature. They provide NOTHING of substance, just a bunch of blanket statements... I agree, in general, that camber is not the issue with this car. It is dynamic toe going into extreme due to worn bushing coupled with worn shocks. If these are fixed and you are DDing with no intent of dialing alignment, they are not necessary. However, having them allows you to alter the dynamic toe range to keep it out of the extreme to prevent scrubbing.
    Are they at least Mz3 owners or have experience with this particular arm design (SPC makes a whole lot of other “types” of arms which cannot be compared)?? It sounds more like they have no respect for a family car (anything but a “sports” car). In my eyes, these arms are a very simple construction which is great. The only way it can fail are due to 1) physically break/crack (highly doubt, unless you set it wrong as in exceeding the A:B gap, then this is user error, see warning in step 8) 2) the busing fail early (possible since it IS aftermarket, time will tell but it look/felt good to me, I also like that SPC bushing are supposedly softer/forgiving like OEM) 3) the lock nut or pinch bolt does not hold (highly unlikely, lock nut is a lock nut and the pinch bolt does not require much force, see step 9). Disclaimer: I only have mind on for ~7 months.
    BTW, I just realized the instructions answered your own questions . But again, the ability to reach the nut is a different question.
    7. Install tire and wheel assembly and lower vehicle.
    8. Adjust camber by turning large 32mm adjusting nut until desired camber is reached.
    Warning: The gap between the large adjusting nut and the outer end of the arm should
    not exceed 12.7mm (1/2”). See Fig #1. Exceeding the range of adjustment of these arms
    may cause the arm to fail and void warranty.
    9. Tighten small pinch bolt and nut to 20 lb-ft. Tighten jamb nut tightly against
    adjuster nut
    Stuff for sale:
    YellowSpeed DPS Coilovers - cheap
    ^http://www.wingood.com/flagselect.asp
    My Thread
    ^http://www.mazdas247.com/forum/showt...oise713-Thread
  4. #109
    Registered Member Secondtyme's Avatar
    2006 Mazda5 Touring
    Join Date
    Feb 2013
    Location
    Glengary WV
    Posts
    900
    To answer your question Moe Drama, you may not need to go all the way crazy as Dave is. The lateral links all by themselves are probably not the source of your clunking, but they may be one of a number of small things that ARE adding up to a clunk. While you are under the car take a close look at your trailing arm bushings and be sure that they are OK, check your springs, make sure that the upper and lower seats (rubber isolators) are in place, not rotted, crooked, or worst missing. Your rear sway bar bushings and end links are another likely culprit in the rear suspension for knocking and clunking. If any one, or two of these things is going on then your lateral links have likely had a lot of stress put on them and will most likely then need to be replaced. Conversely, replacing the lateral links but leaving the other issues un-addressed will not solve your clunking.
    Once I kick this "spend money on dumb shit" addiction I'm set... The Phen
    Killed by deer 3/2016 @221,000 miles much loved, and sorely missed
  5. #110
    Mazda 5 GT 2009
    Join Date
    Sep 2013
    Location
    Winnipeg MB Canada
    Posts
    21
    Thanks for the input, i'll jack it up and have look at that stuff. The sway bar bushings and links looked ok but ill give them a solid wiggle to check this time. We do load up the 5 and tow a fibreglass camper a few times a year and i'd like to upgrade any weak links under there if possible.
  6. #111
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Well that was short-lived. *sigh*. Never even got around to putting the front FSDs on there. Front suspension was going to be a spring project.
    What a waste of time and money. Totaled. No idea how the hell she managed to pull this off.
    2008 Grand Touring, purchased brand new. New trans put in about a year ago.
  7. #112
    Registered Member p h a n t o m's Avatar
    2006 Mazda 5 Touring
    Join Date
    Feb 2014
    Location
    Hawaii
    Posts
    38
    Picture doesn't show up.
  8. #113
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Quote Originally Posted by p h a n t o m View Post
    Been tricky hosting with Google+ lately. Should be fixed now.
  9. #114
    Registered Member
    Join Date
    Mar 2019
    Posts
    1
    Quote Originally Posted by Dave88LX View Post
    I know this is a old thread, but how did the rear end "finish up" ride wise? I ask because i just bought a 14 Grand Touring and i notice how stiffish the suspension is, so i was going to upgrade it. Any thoughts would be great.....
    Also any known issues i should look out for would be great, thanks in advance...
Similar Threads
  1. Replies: 5
    Last Post: 08-14-2015, 04:06 PM
  2. Replies: 15
    Last Post: 07-18-2013, 10:32 AM
  3. Replies: 3
    Last Post: 11-09-2011, 03:00 PM
  4. Replies: 28
    Last Post: 03-21-2003, 12:00 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
