VersaTuner - tuning software for Mazdas
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 114
Thread: My "follow-along" Mazda5 Suspension upgrade
  1. #46
    Registered Member Dave88LX's Avatar
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    I haven't replaced them yet, still sitting in the box. Been tied up with other things.
    But I'm going to need to put new tires on too! What other components in the rear are guaranteed to be shot to be causing this besides the shocks?
  2. #47
    Registered Member Rally Man's Avatar
    6 hanging with the 5's
    Join Date
    Nov 2011
    Location
    91763
    Posts
    461
    Do you have camber arms? Looks like you need them just like I did. Also check out your trailing arm bushings.
    2014 Mazda6 iTouring Snowflake White Pearl
    SunTek carbon 35/18 tint | VLEDS 5K interior | SS scuff plates
    2010 Mazda5 Sport Liquid Silver Metallic - totaled 4.3.15
  3. #48
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    I have nothing, everything is factory.
  4. #49
    Registered Member
    Join Date
    Dec 2009
    Posts
    83
    Replacing my trailing arm bushings with Energy Suspension polyurethane helped with my tire wear. You might have worn trailing arm or toe arm bushings. The toe arms are fairly inexpensive and easy to replace. These vans do tend to wear out the rear tires due to excessive camber though even with everything as new.
  5. #50
    Registered Member Silentnoise713's Avatar
    2008 Mazda5 Grand Touring; 2009 Honda Fit Sport/Nav MT
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Your shocks are toast, which leads to added wear/tear on the bushings, which exacerbate your toe into extreme negative space.
    Google/Read up on dynamic alignment and dynamic toe.
    Stuff for sale:
    YellowSpeed DPS Coilovers - cheap
    ^http://www.wingood.com/flagselect.asp
    My Thread
    ^http://www.mazdas247.com/forum/showt...oise713-Thread
  6. #51
    Join Date
    Nov 2011
    Location
    91763
    Posts
    461
    Forgot to ask, how those Continental DWS holding up? I've been eying getting either DW or RE760's.
  7. #52
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    They were holding up good until, well, you know.
    Silentnoise -- makes sense. I haven't had a moment to read through this thread again to even see where I'm at, I got caught up with a bunch of other things. I can't ignore the problem anymore now though. I just hope I don't have to replace everything on the ass end.
  8. #53
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Well I re-read the thread. I guess I have to do some digging around on here to find the rest of the parts that I'll need.
  9. #54
    Registered Member Secondtyme's Avatar
    2006 Mazda5 Touring
    Join Date
    Feb 2013
    Location
    Glengary WV
    Posts
    900
    Yours looks exactly like mine did before I started replacing parts Dave! I replaced the following and the problem is 100% fixed : Trailing Arm Bushings on both sides with OE spec, not poly, Lateral Links, both sides with Moog from Advance Auto, rear shocks with OE Spectrum and shock mounts Moog. I know the OE Spectrums are supposed to be crap but they have done great for the last ten thousand miles on mine. The single biggest contributor to the alignment being so screwy is the bushings on the trailing arms, mine were so bad that when I removed the trailing arm from the car the metal center bar that the mounting bolts use to hold the arm to the car just fell out on the ground! You will have to have a shop press to get the old bushings out and the new ones in if we haven't already covered that ground somewhere in this thread LOL
    Once I kick this "spend money on dumb shit" addiction I'm set... The Phen
    Killed by deer 3/2016 @221,000 miles much loved, and sorely missed
  10. #55
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Why the OE spec over something aftermarket on the trail arm bushings? As far as I'm concerned, the rear end OE parts are junk! Haha.
    I might have to get a manual to figure out how to get the rear suspension parts off. Everything I've worked on has been a RWD solid axle. I don't know these new-fangled fancy cars! Are there any how-to guides on getting this stuff off?
  11. #56
    Booga Booga? phunky.buddha's Avatar
    2009 Mazda5 Sport
    Join Date
    Jul 2011
    Location
    DFW Metro, TX
    Posts
    1,586
    The big bushing on trailing arms for multi-link suspensions tend to support a pretty complicated range of motion... they not only pivot across the mount axis, but sometimes rotate in and out and twist in weird ways too. If you replace the bushing with polyurethane, you tend to give up a lot of the factory designed motion and start binding up the suspension, causing other problems.
  12. #57
    2006 Mazda5 Touring
    Join Date
    Feb 2013
    Location
    Glengary WV
    Posts
    900
    Well said ^^ And I needed more noises coming from under the car like I need a hole in my head. Once you get the car up in the air you will see that the disassembly is really pretty straight forward. You shouldn't have to remove the upper (camber) arms and those are the ones that can be a PITA to remove the hardware from. The worst part of the job for me was jockeying the trailing arm into my shop press and keeping it properly aligned to drive out the old bushing (which was a bitch) and then driving in the new ones (which was a really big bitch) The new bushings have to be aligned correctly so that the holes in the mounting bar are facing the right direction, if you get it wrong you will wreck your new bushings very quickly. I enlisted the aid of my lovely wife, who got to hear every one of my favorite bad words about 100 times while we did this. Doing the front struts was a comparative walk in the park....
  13. #58
    Join Date
    Jul 2008
    Location
    MD
    Posts
    107
    Ah, I see where you're coming from with the range of motion, didn't think of that aspect of it. Now if it's the same suspension as on the Mz3 and Focus and those bushings are sold for those cars, what makes it bad on this one? Is there an aftermarket option that is better than OEM though? Not too impressed with the OEM suspension parts.
  14. #59
    2006 Mazda5 Touring
    Join Date
    Feb 2013
    Location
    Glengary WV
    Posts
    900
    They fail because Mazda didn't figure the extra weight of the 5 would be enough to compromise the bushings that work just fine on the lighter car. They gambled on that deal and we, the owners, lost. To be fair the bushings do last a long time, just not as long as they might have if the right Durometer had been used from the get go.
  15. #60
    2009 Mazda5 Sport
    Join Date
    Jul 2011
    Location
    DFW Metro, TX
    Posts
    1,586
    Quote Originally Posted by Secondtyme View Post
    I gave up when the neighbors complained about my grinder and just let the shop put them in on my Civic years ago. I didn't want to torch them out and breathe the nasty...
    Quote Originally Posted by Dave88LX View Post
    There are some really nice expensive sliding metal ball joint replacements (can't find pic right now) that are available to the Honda world- not sure if there's an off the shelf application that'll work for the 3/5/fuckus. They were way out of my price range on my no expenses spared Civic.
    Unfortunately that seems to be the case on a lot of the 5's subsystems.
Similar Threads
  1. Replies: 5
    Last Post: 08-14-2015, 04:06 PM
  2. Replies: 15
    Last Post: 07-18-2013, 10:32 AM
  3. Replies: 3
    Last Post: 11-09-2011, 03:00 PM
  4. Replies: 28
    Last Post: 03-21-2003, 12:00 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
