cool_killed
- 2008 Mazda 5 full load
Hello everyone...i have an issue i'd like to get some help with
Brakes: 2008 mazda 5
recently, i replaced the front and rear rotors and pads and bled the system....one problem...i didn't realize the routine in doing the rear calipers, so: here's what i did - normally the C-clamp system works but it wasn't so i thought to take the caliper off the car (pinching the brake line) and attempting to reset the piston....clamp wasn't working (and i still had not realized the piston needed to be turned as it is pushed in) so i grabbed my hammer and started tapping the piston on my benchtop, fluid would pop out of the hole where the line would normally be each time i hit the piston, and i kept tapping (or hitting lol) and the piston started to go back in, perfect....so i did the same to the other driver side rear caliper, put everything back together, bled and done (so i thought)...i started hearing some kind of rattle from the rear wheels when driving over bumps or cracks in the road (like the pads where loose? and clattering) this would stop when i put my foot on the brake pedal or pulled the e brake up slightly...i called a friend at Budget and he said to pull on the hand brake a tonne of times until they calipers/pads set themselves (this was routine)....well i thought this fixed it but it didn't, and now i was told the proper way to reset the caliper (BUMMER!!) so i took apart the calipers again and, re did them, and re bled them (when i used my pliars to turn and push the calipers, when i turned to the left, the caliper twisted out, when i turned the pliers right, the piston turned in and very easily i might say (ugh)...tried the parking brake routine and still the pads (i think mainly or only the rear passenger side was still clattering)...so now i am at the point where i think when i tapped (or hit with medium force on the piston ) i might have bent or damaged something???? can you guys shed some light on this pls and thanks.
