Gotcha bro. What camera you use for your video? Btw, blue CX-5 are the fastest (drive2)
your basic go pro hero 3+
Howdy Placcy,
Congratulations on the New CX-5, and Thanks So Much
for the neat Video's. They are very well done and excellent
clarity.
I have to say, I've never seen plugs/patches like that either,
really neat to see though.
I was wondering are the low profile 19" tires more prone to
road hazzards than any other tire? I've never had tires that
Size so just wondering?
Look forward to following your documenting your new CX5
when you find new things.
Take Care,
Craig
Lets not lump a 225/55/19 into a "low profile" category. Far from it!
True!
Low profile to me is 45 series and lower.
True!
Depends on the width of the tire as well Many trucks use a 275/45/20 these days.
Profile height is the percentage in relation to the width. Using the example- 275/45/20
275= 275 mm wide from sidewall to sidewall (uninflated)
45= 45% of 275 mm. In this case, about 124 mm.
20= 20 inches in diameter.
A 205/45/x'a sidewall will always be shorter than a 275/45/x'a sidewall
(92.25mm VS 123.75mm)
Manufacturers use these numbers only as an approximation, however, as a Michelin may be wider or thinner than a Continental with the same numbers, respectively.
and the wife calls again today.. tire light on and she's on the freeway.. WTF man.. i mean logically it can't be the cars fault, but man its suspicious. ill check for nails when i get home, and prob make another video.
yup toyos
