You know it Chan there quite Robust lol! Im glad you like them tooIve got those too, and there great.
Yeah 14 mm for the inside hex nut that"s to allow you to tighten the 15 mm nut on the Bolt where the Ball joint is.do these use 14mm nut?
can you get us a link to where to get these links?
Yes they do its actually a 14 mm nut on the inside that uses a wrench for it to hold it from spinning then the actual nut that goes on the bolt is a 15mm. I just use a Box wrench ratchet to snug it down and that works perfectly. Just make sure you tighten it to 40 pounds and your done! I hope that helped!do these use 14mm nut?
