So I recently found that my wife's P5 had a broken AC hose which caused the system to loose all of the Freon. I will be replacing the hose today thanks to my friend Neaspeed who was able to supply this hose. Now the question is, does anyone have a how to recharge the AC system at home type of guide? I called a local shop and now and days they want $200 to flush and recharge the system. I can rent a vacuum pump but, do not know where to install a pressure gauge to make sure the system has no air in it. I also wanted to know if is was better to buy the Freon with the oil inside and how many cans should I get with oil? I do not want to put more oil than what is needed. Any input will be really appreciated.
