I have 2011 escape end links, bolted straight on and being 20mm longer than stock they suited me 30mm drop perfectly, they handle perfectly, can't remember any greasing issues but not sure if they are moog though.
Value Craft .Hmmmm. . ..There like the cheaper brand i dont think there as good as Moog but im glad you liked the handling of itIm running the 03 escape links, got them from autozone. Brand is value craft with grease nipples. As soon as i rode off the handleing was differnet, like very responsive, loved the mod i would recommend it for sure.
IF IM NOT MISTAKEN THEY WHERE A BIT SHORTER AND THICKER, OR WAS IT THE OTHER WAY AROUND. NOT SURE BUT LOVED THE RIDE
Oh ok that helps a little but why would you put longer End links on your Protege especially when your car is lowered over 1.18 inches. wouldn't that put more of a weight strain on your ride? Plus those 2011 Escape end links are really skinny i like the 2003 Escape end links there thicker and more robust!
Oh ok i see what you mean. i still like the more robust escape end links even though i dont have them. There Ideal for lowered cars on P5"sNo, it maintains better geometry to the sway bar, as you lower the strut mount goes higher into the wheel well so the longer links keep the sway bar more parallel.
