Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 76
Thread: Installing A Dash Cam
  1. #61
    Registered Member katmar's Avatar
    16 CX-5 GT and 13 CX-5 Touring AWD
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    219
    Quote Originally Posted by tomcat1446 View Post
    just to confirm, this is the one you bought right ?
    Yes. Final receipt said:
    1 x #I01USB - USB 5v Invisicords (mini/micro, for GPS/Dashcams) (I01USB) = $29.20
    Fuse Option Add Fuse
    Connector Type Micro (1/2 x 1/16)
    Re: voltage, the final output is 5v, but I'm not sure if that little box in the cord steps it down from 12v or if it's 5v at the mirror.
  2. #62
    Registered Member
    2019 CX5 GT-R
    Join Date
    Apr 2016
    Location
    Ontario
    Posts
    89
    Quote Originally Posted by katmar View Post
    I purchased the version with a fuse.
    Pictures attached
    This is a 2016.5.
    Hello
    Isin't that supposed to be a Mini USB pin connector at the Dash cam end ? The Transcend appears to be taking a Mini one
    http://www.powerlet.com/learningCenter/usb-connectors
    - With Regards
    PMA (2019 CX5-GTR)
  3. #63
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    219
    Quote Originally Posted by pradeeshma View Post
    Hello
    Yup. The cord came with a Mini Plug end (which I used), but also included an adapter to make it Micro if needed
  4. #64
    Registered Member
    2019 CX5 GT-R
    Join Date
    Apr 2016
    Location
    Ontario
    Posts
    89
    Pictures attached
    This is a 2016.5.
    Hello Katmar
    Sorry to bother you again. The wire connection behind the rear view mirror. Is there any clips to pull it. I tried mine but not helping, just trying to be careful here and didn't want to break it.
    Regards
  5. #65
    Join Date
    Apr 2012
    Location
    New Jersey
    Posts
    219
    Hello Katmar
    If I remember correctly, I think there's a tab on the top of the plug that you need to press down as you grasp the wires and wiggle it out
    Not 100% sure though...
  6. #66
    Registered Member
    2019 CX5 GT-R
    Join Date
    Apr 2016
    Location
    Ontario
    Posts
    89
    Hi All
    In the attached Fuse diagram of CX5 2016 Tech, We can see ports 12 - 16, 18,19 etc are not used by any devices internally. Can we attached a fuse in any of these unused ports for the Dashcam ?
    https://drive.google.com/file/d/0B6S...ew?usp=sharing
  7. #67
    Registered Member
    Mazda cx5
    Join Date
    Jan 2018
    Location
    China
    Posts
    6
    When arranging the cable,we should pay more attention to follow detail :
    First, In the dash cam USB interface, you should reserve some length to buffer because the car have bumps on the road, if the cable pulled too tight, it will break down easily.
    Second, a small transformer between the dash cam and the roof panel, which we can stick to with prepared double-sided glue to make the wiring more beautiful.
    When installing dash cam, you are able to get perfect if you pay more attention to above mention.
    I learned how to install a recorder through this tutorial:http://www.azdome.hk/news-detail-135.html
  8. #68
    Registered Member Triton46's Avatar
    2013 Mazda CX-5 GT
    Join Date
    Nov 2009
    Posts
    175
    Garmin Dash Cam 45
    2013 Mazda CX 5
    I just purchased an Inviscord for my 2013 Mazda CX 5, however the power mirror connector is different from the posts here. On the 2013 the bottom row of the power mirror connector has a blue and red wire and on the top row I have a single black wire. The red/black wire connected to the Inviscord and my dash cam start the dash cam. However, I do get a warning that the cord will not charge the camera.
    Another issue, this only works when the power mirror connector is NOT plugged into the mirror. When I plug it into the mirror, the dash cam will not start. Any thoughts?
  9. #69
    Registered Member Iwannacx5's Avatar
    Eternal Blue 2017 CX-5 GT AWD w/Premium
    Join Date
    May 2017
    Location
    Kansas City
    Posts
    154
    I have the Garmin 55 with the invisicord setup in my 2017 CX5. It doesn't work very well as Garmin's power cords are proprietary and the invisicord will not keep up with the charging. Just wanted to let you know that you will encounter this once you have it connected correctly.
  10. #70
    2013 Mazda CX-5 GT
    Join Date
    Nov 2009
    Posts
    175
    Thanks for that info. I received a reply from Inviscord that this has to do with Garmin using 18kohm power supply through the USB connector. How long ago did you get your Invisicord? I mistakenly ordered a mini USB instead of a micro and tried to address it with a mini/micro adaptor suggested by Invisicord which did not work. I'm going to return the cord for a switch to the correct USB. Also, does your Inviscord have an integrated fuse?
    Here is what I found: My CX5 has three wires for the mirror (red, blue, black): Previously I had no power on blue, I think I had a bad connection and tried it again this morning.
    Car Off (Mirror Cable Unplugged from Mirror)
    red/black shows 0v
    blue/black shows 11.9v
    Car Accessory On (Mirror Cable Unplugged from Mirror)
    red/black shows 0.3v
    Car Accessory On (Mirror Cable Plugged into Mirror)
    red/black shows 0.2v
    Does my model year not have a 12v connection that turns off and on with the car?
  11. #71
    Join Date
    May 2017
    Location
    Kansas City
    Posts
    154
    I bought the invisicord a year ago next month, so I've been dealing with the camera just going dead on my commutes (45 min) each way from/to work. Sometimes I'll get the 45 minutes out of it depending on the starting charge, but most times I don't. I really need to look into getting a different setup and removing the invisicord but I already spent the money on it... You know how that goes. Also hoping Garmin will allow other power cables via a software update, but that's probably not going to happen. And yes, I bought the invisicord with the fuse.
    As for you power supply issue, sorry I can't help there.
  12. #72
    2013 Mazda CX-5 GT
    Join Date
    Nov 2009
    Posts
    175
    Quick update. Inviscord sent out a new cord with the micro usb, same issue, no charging. It seems this will only work for non-Garmin dash cams.
  13. #73
    Registered Member
    Join Date
    Oct 2019
    Posts
    2
    Quote Originally Posted by ssl1900 View Post
    I got a question about the Parking Protection on the dashcam features.
    I understand that it can also record when your car is parked. The one thing I dread is someone hitting my new cx-5 while parked and taking off.
    Does the dashcam parking protection feature actually work?
    If it records any movement while the car is parked, wont it almost always be recording and therefore overwriting your older surveillance constantly?
    From what I have read, the cam uses the battery of the car. So if the ignition is turned off, I don't think power goes to the cam, hence no recording is done. I am yet to get a dash cam, but I am seriously searching for. I have been reading many cam reviews on this website, but can't pick one. Can I get a recommendation from a pro here?
  14. #74
    Work in Progress sm1ke's Avatar
    Contributor
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    2,046
    Quote Originally Posted by fastman View Post
    You can wire the cam to an "always-on" circuit to ensure that it's always getting power, and thus, always recording. In my CX-9, I have my dashcams wired to the homelink rear view mirror. I used the Invisicord. Some dashcams have a parking mode that keeps it in a low power "standby" state until it detects motion. Others use a different parking mode where the camera records a time lapse until the motion detector is triggered, then it switches to normal recording. This is done to minimize the space taken up by the recording on the micro SD card.
    Personally, I've been using the Viofo A129 Duo set of dashcams. The package includes a front camera and a rear camera, with WiFi capability, 1080p recording, parking mode, motion detection, GPS, etc. Been using this setup for nearly 2 years now, and it works great.
    Also a note on the "always recording, constantly overwriting".. yes this is an issue, but if you buy a dashcam that can handle a large capacity micro SD card, and use a large capacity micro SD card, it doesn't really matter. Mine is always on and recording in 1080p, but I'm using a 256gb microSD card, so it will record 3-4 days worth of footage before it starts overwriting the older footage (and this includes the additional video files from the rear cam). If I come back to my car and see that it has been damaged, I can easily go through the footage.
  15. #75
    Registered Member
    Approved Merchant Member
    Join Date
    Aug 2019
    Posts
    10
    @Iwannacx5, did you ever resolve this issue? I don't understand the nuances of the Garmin camera or which buck converter Invisicord uses, but it would be great to see if my own wiring product will work for you:
    https://www.amazon.com/dp/B07KZSBC54
    Message me if you want more info!
Similar Threads
  1. FS: Dual Dash bezel gauge pod,custom painted Dash bezel
    By Discospeed in forum Mazda Protege For Sale
    Last Post: 09-13-2012, 01:22 PM
  2. Replies: 60
    Last Post: 01-31-2012, 10:22 PM
  3. crack on my dash board need help removing dash Board.
    By heman in forum Mazda3 Infotainment
    Last Post: 02-07-2010, 10:08 AM
  4. Pioneer F700BT in-dash Vs. Kenwood 5120 in-dash
    By seattleMS3 in forum Mazda3 Infotainment
    Last Post: 02-18-2009, 02:16 PM
  5. LCD in-dash or out of dash monitors
    By BlueMP5Dave in forum Mazda How-To
    Last Post: 01-11-2004, 04:58 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
