electric windows
morty8747
mazda5
having problems with my windows
they were working fine yesterday on the key fob , but now all the windows open and close as they should when holding the lock or unlock button apart from the drivers window,
but it does work on the switch inside the car
any ideas ? cheers
Hi
I have the other way around. From the drivers seat I cannot control the other windows and pressing the lock/unlock, only the drivers window reacts.
I checked all fuses and they seem fine. So I hope it is not a cabling issue between the door and the chassie.
Hi Westenc. I have the same problem as you. Did you get it fixed? and if so how?
I got it working! (google found it on another site)
Try this:
(1) Turn ignition to ON
(2) Press a window switch to fully open the window (not using the switches on the drivers door)
(3) Pull up the switch to fully close the window and continue holding the switch for 2 seconds after the window has closed
(4) Repeat for each window
