we did and nothing would get it, would a shop have the tools to pop it? i really need to save the cv axle if at all possible because a new (good one, not cheapo) is too much for me to buy
i am having a similar issue and knew what to do, jacked the car up and confirmed wheel bearing was bad, i have a question i need answered my cv axle is stuck in the hub will a shop with a press be able to save my cv axle and hub or will one the other or both be destroyed in the process?
I put the axle nut back on to protect the threads a bit, and gave it a couple of good wacks with a sledge hammer. Both sides out without much fuss.
i am letting a shop do it, i let them know it was stuck when i went to do the clutch a few months back they said no problem they can get it, i did let it soak in pb blaster over night so that should help them some. so $160 later ill have it fixed. but better to pay a shop that amount then take it apart myself have to buy a new cv axle and still pay a shop to press in my bearing. ends up saving me $130ish over buying a new cv axle from mazda, as aftermarkets tend to not work right long. i work at autozone and we get several returns on even the new duralast gold (made by a1 cardone) cv axles as they use a different joint style then oe and it tends to fail quicker.
Hi guys, CARDONE here. We saw this post pop up and thought we'd chime in.
We currently DO NOT provide Autozone with their NEW CV Axles.
Also, for future reference all Cardone reman products are considered: A1 CARDONE. Our brand new products are labeled as: CARDONE Select
Thanks!
Thanks!
i am letting a shop do it, i let them know it was stuck when i went to do the clutch a few months back they said no problem they can get it,,...
i was wondering the same thing, they caught that way too quickAssuming this is actually a rep from Cardone, how did Cardone realize it was mentioned in a thread on mazdas247 and suddenly show up? Strange.
If they (Cardone) are smart, they have Google alerts setup and let them do all the work.i was wondering the same thing, they caught that way too quick
i dont use cheap parts i use quality parts.
