bigsho
2007 Mazdaspeed3
Sohan Ghosh
H&R Coilovers, Hotchkis 32mm front and rear sway bars, SPC camber arms, Cp-e 75d RMM, JBR 80d TMM & PMM, Cobb AP, Autotech hpfp internals, HTP 3.5" intake, UR downpipe, eBay racepipe, SU TMIC, Forge V1, Mazdaspeed Accessory CB-E, PnP IM w/ vtcs delete
Herblenny
Phil Sohn
1993 RX-7
<iframe width="640" height="360" src="//www.youtube.com/embed/2taIgJVe6KY?rel=0" frameborder="0" allowfullscreen=""></iframe>
Engine:
- Adaptronic ECU for FD PNP (
http://www.turblown.net/store/index.php?productID=280)
- Garfinkle Delrin Custom mounts
- Pettit Polished AST
- Koyo N-Flow Radiator
- Custom Carbon Fiber Cooling panel
- Fast acting AirTemp sensor
- BNR Stage 3 Twin Turbos
- Ported 13B-REW engine
- Custom Grounding kit
- Polished Efini Y-pipe
- Polished upper intake manifold
- Polished 90mm Rotary Works Throttle body
- Polished Greddy elbow w/injector ports
- Apexi GT Spec FMIC
- Custom polished pipings By: BNRSupercars.com
- Constant tension T-blot clamps for IC pipings and Intakes.
- HKS seq. BOV
- HKS twinpower ignition amp
- RE-Amemiya SS Dual Dolphin Tip Catback
- SS Pettit DP
- Mazdaspeed ignition wires
- FEED oil filler cap
- FEED coolant filler cap
- Added R1 Dual oil coolers
- Braille light battery
- Braille Verticle mounting kit
- Unorthodox Alternator pulley (red)
- Unorthodox Power steering pulley(blue)
- Exedy Hyper Single Clutch Kit
- Simplified seq twin set up
- Polished hardline intake pipes for secondary intake.
- Ported JDM Upper Intake manifold and polished by David Garfinkle.
- Also all the misc. vacuum ports have been welded shut and cleaned up and polished for cleaner look.
- Pettit Racing water pump pulley
- 2 x 4 blade fan set up for better cooling
- HKS RS intake with KN filters
- Tweakit Racing tensioner pulley kit
Suspension:
- M2 launch kit
- FEED coilovers
- Fender Braces
- Racing Beat sway bar brace
- Racing Beat sway bars (front and rear)
- AutoEXE front brace
- Racing Brake Rear Brake kit with HP+ pad
- Hawk HP+ pads rear
- Newly sandblasted A-arms and other suspension parts
- SakeBomb AP Racing Big Brake Kit with Ferrado pads
- Braided SS brake lines
- Racing Beat sway bushings
- New Delrin bushings for all suspension parts
- Transmission brace
- Raceshop Rollbar
- Dragon’s diff brace
- Rays Engineering Volk Racing TE37SL 189.5 Front and 1810.5 Rear.
- Toyo R888s 255/35 front and 295/30 rear
Interior & Stereo:
- Works Bell Short hub
- Works Bell Quick disconnect
- Works Bell hub lock
- Personal Steering wheel
- Converted Black interior – including, door panels, rear panels, head liner, seat belts, and black main carpet
- RZ floormats
- Rare moon roof interior cover
- JDM rear seats with panels, seat belts, and special rear carpet
- Bride Artis III Navi
- FEED Shift knob
- Red leather stitching shift and ebrake boots
- LED interior lights
- RE-Amemiya steering column pod with 52mm Prosport boost gauge
- JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (Flattened look)
- JVC 7inch AV system
- RE-Amemiya speedo cluster gauge
- FEED Carbon fiber rear trunk add on.
- Base model hatch cover
- OEM fog light switch to turn FEED HID driving lights
- Carbon look oem door step
Exterior:
- Plasti Dip Storm Cloud Grey exterior (
www.DipYourCar.com)
- Carbon Vented hood
- APR GT300 with custom aluminum stands by Adam Griffith
- One off Feed Carbon Gas door (Shine Auto)
- Feed Type 2R front bumper
- Feed Carbon fiber canards
- Feed Carbon Fiber side skirts
- Feed wide front fenders
- FEED rear wide flares
- Rotary Extreme hood dampers
- R-magic oil cooler ducts
- FEED front tow hook
- Adam Griffith rear tow hook
- RE-Amemiya Pro Carbon rear diffuser
- Custom LED tail lights
- Custom rear bumper CF signal covers
- Rare glass moon roof
- LED signal lights in FEED signals
- HID FEED Signal lights
- Spirit R fender badges
- Efini front are rear badges
- Carbon look rear bumper lights
- Carbon fiber FEED gas door (one off made)
- APR Carbon Fiber side Mirrors
- Custom front canard add on
- Carbon Cooling panel (custom, made by me)
- LED Front bumper strips
- R-Magic HID head lights
- FEED door handles
- Carbon Fiber back of the door handle covers.
- Back Off 3rd light flasher
- ShineAuto rear tail light lip
- Feed carbon Fiber bumper guard by Shine Auto
Recent Accomplishments:
SouthrnFresh feature Feb 2014
http://southrnfresh.com/2014/02/phil-sohns-mazda-rx7/
Import Tuner feature April 2014 issue
http://www.importtuner.com/features/...993_mazda_rx7/
Maleskimp3
Nate Maleski
2001 MP3
Mod list
Engine
Paulter Rods
Wiseco Pistons 83.5
ACL Race rod Bearings
PTE 6262
Cometic headgasket
Cometic exhaust gasket
Cleveite Main Bearings
*Block casting cleanup
AWR oil pan
*Port and polished head
*Torque Plate
Super tech dual springs
Super tech Ti retainers
Super tech +1mm Intake Valves
Super tech +1mm exhaust Valves
*Valve shims
SRS cam gears
*Cam sensor pickup
ARP cam tower bolts
ARP cam gear bolts
ARP valve cover bolts
*Water pump Impeller
*Fuel Rail
*Dual PumpIn tank pump holder
x2 Jay Racing PT342 Fuel Pumps
Aeromotive FPR
Golan Fuel Filter
Earls and Vibrant AN Fittings
*Exhaust Manifold
*Full exhaust
*WG dump tube
Tial MVS waste gate
*One wire alternator brackets
Chrome One wire alternator
*Custom boots with MSD wires
NGK plugs
ACT 6puck sprung
Fidanza fly wheel
MSP axles
*Thermal Spacers
*Intake Manifold
ARP intake studs
Vibrant Silicone Couplers
Vibrant T-bolt clamps
*All intake pipes
Tial Q BOV
Green intake filter
Carbon velocity stack
Greddy catch can system with E vac
Jay Racing Vac Block
Holley 75mm Mustang TB
Eat Sleep Race Inter cooler
Modified Crash bumper to fit
Corksport Radiator
Spal Slim fan
Greddy Coolant overflow tank
*Coolant line relocation block
AWR complete engine mount kit
Powder coated almost everything I could think of to powder
Electronics
AEM EMS4
AEM Smart Coils
AEM wideband
AEM oil pressure gauge
AEM true boost
Autometer Tach
Autometer shift light
*Push button start
*Replacement main relay board
Rear ABS sensors for launch control
Dry Cell Battery
Interior
Sparco Evo 2
*Sparco seat mount
Sparco FIA Harness
Momo E brake handle
Momo RACE steering wheel
NRG steering wheel adapter
NRG steering wheel quick detach
*Carbon Laptop stand
CR3 dead man pedal
3 pillar pod
Switch panel for fans, fuel pump, ign, etc...
*5 Point Roll Bar
*Customized rear seats that still fold down with Roll bar.
*Weighted shift knob
*Re worked Short shifter and ball bearing linkage
Exterior
VIS Carbon Hood
Carbon trunk
Carbon Grille
HID lights
Jay Head wastegate dump
Aeroquip hood pins
Vortex generator from STI
ARP fender bolts
CR3 ADP
CR3 radiator mounts
3.5 MSP rear lip
JayRacing Stickers +6 hp
Suspension/Wheels
M&H Slicks 23 1/2"
15" Rota slipstreams
Bridgestone Potenza
Kazera wheels
Yellow Speed Coilovers
Ladder Brace
V brace
Lower tie bar
Megan Racing trailing arms
Progress 21mm rear sway bar
*Sway Bar relocation Brackets
*Rear sub frame mount (CR3)
*Aluminum Lateral arms
*Titanium long bolts for lateral arms
*Front sway bar end links
*Rear sway bar end links
EBC Brakes
Drilled and Slotted Rotors
Anything with "*" are things I've made at JayRacing
mini_FD
Gerald Mugar
'99 miata
Engine
megasquirt 2v.3 built by reverant
Gt2560r dynod at 257 whp and 259 torque at 14lbs.
Flyin miata kit II
Koyo 53 mm aluminum radiator
Mishimoto silicone hoses
Arc radiator cap
Mishimoto slim fans and shroud
ev14 460cc plug and play injectors*fiveo motors ports
190lph walbro
Transmission
Spec 3+ 6 puck sprung clutch
8.9 lb fidanza lightweight flywheel
Mazdaspeed miata complete rear end 4.1 lsd, axles and drive shaft
Suspension
Autoexe 3 pt. Strut bar
Tein flex
Jackson racing sway bars
V8 roadster frame rails
Racing Beat polyurethane end links
Mazdaspeed competition motor mounts
Energy bushing polyurethane differential mounts
Brakes
Ebb green stuff
Exhaust
Rsr ex mag I I-
Exterior
2004 Mazda speed miata face lift
garage vary front lip
Autokonexion v.1 duck bill tail
01+tail lights
Garage star hard top spoiler
Oem hardtop
Demon camber precedo 157.5 -5
Rays black anodized lug nuts
Smoked ebay side markers
Led side marker and license plate lights
Garage vary eyelids
Debadged
fresh paint 12\13
S2k radio receiver and antenna-
Rob ryoku red anodized tow hooks
Dz101 Dunlop tires 195 50 15
Interior
Revlimiter's war birds custom gages
Rs meter gauge
Eunos swarkoski blue horn badge
330 mm deep corn red stitch Nardi wheel
daikei hub
!njoy sun visor deletes
Carbine bronze shifter
10th anniversary shifter surround
pioneer stereo
Polk 6 in. Speakers
65 watt mini amp
aem digital water temp gauge
Ebay gauge surround
01 miata seats "surfboards"
01 door panels
01 black carpet
01 ac face amber lighting
Mazdaspeed door sills
ilovewheels
Korban Corbett
2003.5 Mazdaspeed Protege
engine:
custom fmic kit
custom intake
footwork:
megan racing coilovers
17x9 rpf1 on 245/40/17
dunlop tires
exterior:
custom fender flairs
interior:
race bucket
one off ipad indash radio
shifter extender
color matched steering wheel
boost/volt gauge/scan gauge
rally2003
Corey Plotts
2003.5 MSP
Interior:
-NRG steering wheel
-JBR shift knob
-Kartboy short throw
-Polyurethane shifter bushings
-Sparco EVO (driver side)
-Sparco REV (passenger side)
-Custom carbon fiber radio surround with gauge spots
-Custom carbon fiber shifter bezel
-AutoMeter CF oil pressure gauge
-AutoMeter CF boost pressure gauge
-AEM UEGO wideband
-Driver mod...
Engine:
-Full Vibrant 3' exhaust w/ high flow cat
-Corksport polyurethane exhaust
-12lb battery
-Mishimoto FMIC
-Mishimoto full radiator
-Mishimoto dual 12" fan shroud
-626 ported and polished intake manifold
-Split Second Air Fuel Controller
-SU 60 durometer front motor mount
-SU 60 durometer rear motor mount
-AWR 80 durometerside engine mount
-AWR 80 durometertansmission mount
-JayRacing throttle body thermal spacer
-JayRacing intake manifold thermal spacer
-Aluminum hot and cold pipes
Suspension/Brakes:
-AWR 21.5mm rear sway bar (modified)
-AWR adj. rear endlinks
-AWR adj. front end links
-AWR trailing arms
-AWR coilovers
-450lb Eibach front springs
-600lb Eibach rear springs
-Techna braided brake lines
-Drilled and slotted rotors
-Porterfield race pads
-Energy Suspension rear sway bar bushings (modified)
Exterior:
-DGM carbon fiber hood
-Enkei RPF1 17x9 +22 (front)
-Enkei RPF1 17x7.5 +48 (rear)
-BFGoodrich RS1 255/40/17 (front)
-BFGoodrich RS1 225/45/17 (rear)
-3M Satin white vinyl
Removed:
-Full A/C system
-Power steering and lines to the rack (depowered)
-Stereo and speakers
-Backseats and hardware
-Washer fluid bottle and lines
Princess Peach
Pablo Chois
2003 MazdaSpeed Protege
<iframe width="640" height="360" src="//www.youtube.com/embed/O9vlOso5aj4?rel=0" frameborder="0" allowfullscreen></iframe>
Suspension \ Chassis
6 point Self-Fabricated Roll Cage
KSport Coilovers
500 lb/in Front Springs; 850 lb/in Rear Springs
AWR Adjustable 21 mm Rear Swaybar
AWR Front Endlinks
AWR Motor Mounts
Wheels & Tires \ Brakes
Hoosier A6 Tires (225/45/15)
15x8 Rota Slipstream Wheels, 40mm offset (2 sets, blue and black)
Carbotech XP-12 front brake pads
Carbotech AX-6 Rear Brake Pads
Steel Braded Brake Lines
ATE Super Blue *Brake Fluid
Summit Brake Proportioning Valve
ARP Wheel Studs
Engine
AWR Oil Pan
Injen Intake
Self-Fabricated airbox with headlight inlet
Hardpipes
Front Mount Intercooler
Corksport 2.4” S and J pipes
2.5” Catless Midpipe
Self-Fabricated Midpipe-back Exhaust
Fidanza Aluminum Flywheel
Exedy Stage 1 Clutch
Interior
Short shifter
Mazdaspeed shift knob
RCI 6-point Harness
Ultrashield Pro Road Race Seat
Mesh Window Net
Self-Fabricated Seat Mount
Odyssey Battery, Relocated to Passenger Side Floor
SPA Fire Suppression System
Autometer Boost, Oil Pressure and Oil Temp gauges
Longacre HOT LAP (lap timer)
Exterior
Self-Fabricated Front Bumper and Tow Hook **
Carbon Fiber Hood with heat extraction holes
Lexan Windshield
Lexan Side Windows
Self-Fabricated Airdam and Undertray
Aluminum rear spoiler
Removed
Seats
Door Trim
Side Windows
Carpet
Stereo
Airbags
HVAC
Air Conditioning
Interior Trim
Sound Deadening
Muffler
Anything Else Not Needed
