optimaldave
- 2003 Protege5, 5spd
So I swapped my passenger side engine mount today as mine was almost torn in two. However when re-installing the new mount I discovered it appears to be the wrong one... for one thing the new one did not have the bracket to bolt to the engine included and after I managed to extract the old one from the old bracket I found out the shaft was a smaller diameter than the sleeve on the new bracket. Having no choice but to be able to drive my car today I put some electrical tape on the shaft and mounted it up.
Then is when I discovered that the new mount is the wrong dimensions compared to the old one and may have shifted the motor rearward as the mount is completely cockeyed.
I was wondering if some of you can look at these and tell me if it is worth swapping for a Mazda part to make it right again, if i should loosen the motor side and pry the motor forward a bit, and then re-tighten the mounting nuts, or just leave all as it is.
I have done some searching on the site but couldn't find anyone who had gone ahead with the install and seemed to care about any issues that may arise from it.
Cheers
Dave
Cheers
Dave
