I'd like to smooth out the dimming of the map/dome lights with LEDs in place. They tend to flicker/shake lightly as they dim out (for instance after you close the door.) I was thinking of wiring in a parallel resistor to add load to the circuit but part of that is dependent on the type of dimmer it is. Anyone have any info/thoughts? I haven't found the wiring diagram yet, but since there is limited room in the light housing, I was looking to tap the resistor into the circuit near the fuse box.
