the fans clear the SC and header without issues on the back of the rad. Since i installed the rad the temps have been much better then with the OE crap and i bet those 2 fans came on last year about 6 times over the 35K miles i drove the car. I might build a shroud and attached the fans to the shroud and have them mounted as pull fans if i notice any changes in temp.
I was just pointing out that generally cooling fans work more efficiently as pullers than pushers since the latter actually block portions of the radiator. Pullers are even better shrouded. It's not like the FSDE gets particularly hot anyway. I had two unshrouded 12 in. SPAL puller fans on my Corksport radiator it it usually took something like 15 minutes of idling to kick the fans on. I remember thinking for the longest time I had wired them incorrectly.
