Bikingpro5's build 2
bikingpro5
03 Protege5
Alright last build got too long so i decided to start a new one for all of the new changes and parts.
recent picture from before this winter
last photo before the car started coming back apart for the winter to make changes.
old build thread that became to long
http://www.mazdas247.com/forum/showthread.php?123773756-Bikingpro5-supercharged-Protege5
Engine bay before winter 2013
So under hood highlights you can easily see are.
Perrin fuel rail
626 intake manifold
M62 clutched supercharger
CR3 ADP
CR3 Rad brackets
relocated battery
GT Spec rear cage and relocated lightweight battery
triple gauge in center console surround
rewrapped speed3 front seats- leather/suede with blue stitching, you can also see the CDM raised armrest and matching leather arm rest
so since i moved into a new place this fall which had my own garage many changes are going to happen over the winter.
first was a set of 17" RPFs that i bought from Evan
had them refinished in bronze to match the rest of my powder
next big change was a set of lateral arms made by Nate at Jay Racing. It feels great to know that this is one of a very limited run that he made (1 of 2)
beautiful SS bushings
then instead of that stupid long bolt that is impossible to remove after a few years, he machined 2 long bolts so that we could use nuts on each end
rods taped up to protect them during install and the bags of SS hardware
while the subframe was out i had it coated in wrinkle black, installing the bushings and heims
was at this point I learned that i had installed the wrong bushings. 12mm and 14mm so we had to remove all 4 heims and bushings and replace them with proper ones
the long bolt did not fit the bushings is how we learned I had 2 separate sized bushings and i had grabbed the wrongs ones first
installed
Bushings at the rear hubs
view from behind the car
putting the rest of the suspension back under the car
while the subframe was out i also cleaned and swapped out the broken pieces on my coilovers.
next to change was the small battery in my hatch, I had yet to see anyone install one where the OE jack normally is so i decided i wanted to try.
battery bracket also wrinkle black
battery installed and works great
cleaned up a few more wires under the hood
before
during
after- IC piping is also wrinkle black now instead of garbage grey-black
installed a CF delete panel made by Corey
pile in the basement before i installed the rear subframe and laterals
so yesterday after bolting up the rear suspension i decided to see if i could spin the car around so i could work on the front suspension and not be near the cold garage door.
once spun around i lifted the car again on the stands to remove the front suspension parts for cleaning/powder
Ooh this makes me so excited to finally have a garage in August! I hate having just a parking lot and walking up and down stairs with all my parts and tools.
So what company is it then ? T1r?
Deka makes the Braille batteries this one is the 11lb version
ya we moved end of September and its great being able to go wrench when i feel like it, but i still walked up and down the stairs for all of my parts and most of the tools until i started to leave things in the garage. Until i have my cabinets installed and finished in the garage most of my tools will stay in the house out of the cold.
So that's what Evan did with my old P5's wheels. Good to know they're still kicking around
Inspiring build ! That's the blue im spraying mine with some gold flake :) I really like what you have done with you're p5!
thanks, the OE laser blue is a bit lighter then what i had the car resprayed.
So 2 years of DD means for some dirty coilovers when it came time to taking them apart for cleaning and making sure everything was good for the next little while
everything came apart easily minus the lower mount which took some time to soak and needed a bit of help to knock the dirt out of the threads
how it sat while the lower mount was filled with PB blaster
apart
how the car sits currently while i finish the engine bay and exhaust changes.
starting to reinstall things
Do you have to have the fans setup as pushers to clear the supercharger? I know you don't track the car but it's unfortunate to have that much obstruction in front of the radiator.
The coilovers sure cleaned up though! Makes me think I should do the same.
the fans clear the SC and header without issues on the back of the rad. Since i installed the rad the temps have been much better then with the OE crap and i bet those 2 fans came on last year about 6 times over the 35K miles i drove the car. I might build a shroud and attached the fans to the shroud and have them mounted as pull fans if i notice any changes in temp.
Latest posts
