Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 159
Thread: ATF Drain/Fill
  1. #31
    Registered Member dergibog's Avatar
    Mazda CX-5 '14 GTw/Tech
    Join Date
    Feb 2013
    Location
    Arvada, Coloado
    Posts
    342
    What Kind did you end up using Chris? 80w90? Brand?
  2. #32
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,139
    Did first ATf drain/fill at dealership at 37k miles. Now I'm at nearly 66k miles but this time I want to DIY.
    Questions I have are:
    - Anyone know the part number for the AT plug washer? Just want to double check in case dealership gives me wrong one.
    - Unike the engine oil pan plug being situated at an ideal angle when lifted via ramps, the AT pan plug appears to be flat on the bottom. Would ramps be ok or should I lift all 4 corners leveled?
    - I believe Chris advised the tranny system contains 5 quarts total with aprox 3.5 draining out w/o dropping pan. I'm assuming purchasing 4 (1-quart) bottles is sufficient for this project?
    Thanks guys.
  3. #33
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    912
    Quote Originally Posted by CX-5um View Post
    Thanks guys.
    Please keep us informed as to how this went for you. I'll be doing this myself at some point.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  4. #34
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Arrow ATF Drain/Fill
    Thanks guys.
    For AT drain plug washer:
    [3] Trans pan gasket. 2.0 LITER, AUTO TRANS
    Part Number: 995641400
    MSRP Core Online Price
    $1.17 $0.00 $0.84
    Looks like transmission pan drain plug and aluminum washer are exactly the same as engine oil pan drain plug and aluminum washer. They carry the same part numbers - FS5021249 for plug. So 8mm Allen hex key or bit is needed like engine oil change.
    Some posts from Change automatic transmission fluid? may have answered your questions:
    Quote Originally Posted by Chris_Top_Her View Post
    A drain and fill of approx. 5.1 US qt, per service manual is pretty much the only service regarding the ATF.
    Quote Originally Posted by runtohell121 View Post
    Quote Originally Posted by yrwei52 View Post
    So did you pour in 4 quarts of fresh Mazda Type FZ ATF for the drain-and-fill?
    3 quarts and about ~24 oz, still have a little bit left on the 4th bottle.
    Quote Originally Posted by Kedis82ZE8 View Post
    runtohell121 : Just curious if you jacked up your CX-5 to change fluid or just changed on level ground.
    Jacked up slightly on both side (making it level) to remove the panel and when draining.
    I'd just raise the front a bit with both front tires on 2-layer 2X10 wood board used for my oil change. I can then raise the rear a bit with floor jack to make the vehicle level while draining. You can do the same even with your oil change ramps. According to owner's manual and service manual, total capacity of automatic transaxle fluid is 8.2 US quarts, not 5 quarts! So drain-and-fill method can only replace a little less than half of the old ATF anyway. I wouldn't worry too much about keeping the CX-5 level during ATF draining. Now are you going to be doing drain-and-fill 2~3 times for this ATF change?
  5. #35
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,139
    $1.17 $0.00 $0.84
    Okay thanks for the good useful info. Good thing about Mazda is parts are universal. Example is the same oil filter is likely used from the Mazda2 all the up to the CX-9 Turbo. So the same washer used for engine oil plug being used on the transmission plug comes to no surprise.
    I have good quality ramps but no floor jack. May have to invest in one long enough and spec'd to lift entire back or front end of our Mazdas for future projects.
    At 8.2 quarts ok got it. 4 (1-quart bottles) per drain/fill session. Repeat the process after say 1-2 weeks. I'd say transmission will have aprox. 90% or more of new fluid in it. I'd be set for 3 years at an investment of aprox. $120 in ATF fluid for 2 sessions.
    Some useful general info regarding ATF drain fill and flushes here: https://www.youtube.com/watch?v=o690DovjDAc (Fast foward to the 5:00 mark)
  6. #36
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    ⋯ Some useful general info regarding ATF drain fill and flushes here: https://www.youtube.com/watch?v=o690DovjDAc
    This's my favorite video for changing ATF and filter on a CX-5 by removing the fluid pan:
    This Japanese CX-5 has only 13,121 km / 8,153 miles. This guy put 5 magnetics outside the fluid pan in addition to one stock magnet sitting inside. As you can see there're lots of metal shavings attached to those magnet areas once the fluid pan got removed! This makes me having an urge to remove and clean the pan on my CX-5 right away! I also noticed that the threaded ATF drain hole is reinforced to accept the threaded bolt of the drain plug. Hence the inside of drain hole is not flush with the pan and that tiny "wall" will make some ATF left in the pan even if you keep the vehicle level. Also the part number for Mazda ATF filter is FZ01-21-500 and the funny thing is the stock filter he removed is made in USA!
    This guy used "ThreeBond 1207C Liquid Gasket Reddish Brown" to form the new gasket for the fluid pan. And the spec sheet he used indicates:
    SkyActiv-Drive automatic transmission has 4 models:
    FW6A-EL for SkyActiv-G FWD and FW6AX-EL for SkyActiv-G AWD.
    - Total ATF capacity is 7.8L / 8.24 US quarts.
    - Drain-and-fill estimate including filter replacement: 3.5~4.9L / 3.7~5.18 US Quarts.
    GW6A-EL for SkyActiv-D FWD and GW6AX-EL for SkyActiv-D AWD.
    - Total ATF capacity is 8.0L / 8.45 US quarts.
    The guy refilled with 4.2L / 4,200 cc / 4.44 US Quarts Mazda Genuine ATF FZ during the first drain-and-fill with pan removal and filter replacement. The second simple drain-and-fill he used 3.57L / 3.77 US Quarts fresh ATF FZ. He claimed by doing this drain-and-fill diluting method twice with filter change at first drain, at least 70% of old ATF would get replaced. He also suggested ATF does need to be changed and the change should be made in a clean and dry environment. Finally, he compared ATF after first drain-and-fill and second drain-and-fill, to fresh ATF. You'll be the judge if we need to change the ATF or not!
    Notice that how the guy simply drove up to 4 pieces of 6X6 wood to raise the height of the CX-5 easily and safely in level!
    Yeah, they do sell Mazda Genuine ATF FZ in large 10-liter / 2.5-gallon metal bucket container in Japan!
  7. #37
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,139
    Ah yes I remember this video. Some of that sludge could be during the break in period? Meaning if he were to drop the pan again in the future it would probably take him more than 8k miles to accumulate that amount sludge.
    I was at the dealership this morning getting my oil change and tire rotation done for my 16 Mazda6. I talked to the guy in the parts department and also one of the mechanics there whom was getting a part in the parts room. Both confirmed the washer used in the oil drain plug is the same part as the washer for tranny plug. So I bought a 5-pack of washers. I asked the tech (mechanic) regarding the skyactiv transmission fluid process (keep in mind this dealership did my first atf drain/fill) and he said that roughly 40% of the atf fluid is changed during the process. They normally charge $250 for the service (1 session )although they usually have a coupon to knock it down to $199. For about $120 I can DIY for 2 sessions.
    For the CX-5 which sees 80% uncongested freeway driving by my wife- atf drain and fill for 2 sessions should be good. Simple drain/fill atf x 2 sessions every 30-40k miles should not only get the CX-5 to 200k miles but 200k silky smooth miles at that imho.
    For the Mazda6 it see's 85% street driving and sees manual mode and sport mode a lot more meaning the ATF's protective property lifespan will be shorter. Atf drain/fill will be done at around 30k miles and dropping the pan and changing filter at 60k miles after power train warranty expires.
    Will be doing this project soon in tandem with oil change.
  8. #38
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,419
    I'll tell you what he didn't do...check his fluid level in the trans...
  9. #39
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,810
    Blog Entries
    6
    I'd consider dropping the pan if there was just a gasket used. I'd want to give car a good 24 hours just to be sure liquid gasket seal was good. It will just be drain & refill for me.
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  10. #40
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Quote Originally Posted by madar View Post
    Great point! I guess it's hard for me to "estimate" the proper ATF temperature at 50C / 122F before measuring the fluid level as I don't have an App to read ATF temperature from ECU. Putting exact amount of drained out ATF back is a risky business for Mazda's as we don't know if the ATF was underfilled from factory like many other fluids on CX-5!
    I like Honda's way as the manual gives me an exact ATF amount (3.1 US qt), not a wide range like Mazda's (3.7~5.18 US qt), for ATF change. I simply drained and fill that amount of Honda ATF and be done with it. Don't even bother to check the ATF temperature and measure the level!
    The Japanese video maker does have some sort of pod display on A pillar to read some ECU parameters though.
    6. Idle the car (or drive around the block) to heat up the oil before you take a reading. I've found that idling to get a proper reading may take a while, so give it about 10 mins. You are supposed to check it at 50 c (122f). I did this before I drained and filled and it was reading below, got hotter and it was still below (used torque pro to get atf temp from ecu); it read correctly after I had driven though (tested after a drive with the motor still on, wiped it and retook the reading). Just a head up. Add (or drain lol) atf as needed.
  11. #41
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,810
    Blog Entries
    6
    I thought the ATF temp was available only via something like Scanguage since that parameter is proprietary on Mazda system? Coolant temp shows up on anything I have thrown at it but haven't seen ATF. Willing to try Torque Pro if it indeed shows ATF temp.
  12. #42
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    I only tempted to remove the pan after watching the video and saw metal shavings on the pan. But my conscience told me not to do it with the same reason like yours.
  13. #43
    Guest2019C20
    Guest
    I'm not seeing 'chunks' of metal in that video. I'm seeing what I suspect is normal clutchpack wear, assuming the linings have metal in them, like some brake pads do.
    Note, that's all conjecture on my part, but the fineness of the deposit resembles what I saw when spraying moly lube on something...
  14. #44
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    986
    Has anyone used a vacuum pump to extract the tran fluid out of the fluid dipstick check hole. Most I/O boats come equipped with a screw on option on the dipstick to extract the engine oil as space may be tight under the engine so I have a vacuum pump that has a clear measured container for my boat and I think it will work without taking the bottom cover or plug out...
  15. #45
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,139
    Quote Originally Posted by GAXIBM View Post
    Don't see why not. Just not sure how far down you could go though. If you could only extract like 2 quarts then I'd pass and go with the gravity drain.
    Always had good results on my Mityvac evacuator on BMW engines. Then again BMWs and Mercedes were designed for pumps. My brother was a Mercedes tech and thats how they do their oil changes at dealerships.
Similar Threads
  1. To the transmission drain & fill folks
    By bullseye in forum CX-9 Engine & Transmission
    Last Post: 03-30-2012, 06:54 PM
  2. Transmission drain and fill plugs
    By BoostedSpd6 in forum Mazda6 Engine & Transmission
    Last Post: 08-26-2007, 04:56 PM
  3. m/t drain plug and fill ???
    By dupakupa in forum Mazda6 Engine & Transmission
    Last Post: 12-18-2006, 04:43 AM
  4. Transaxle drain & fill
    By JFW in forum Mazdaspeed Protege
    Last Post: 03-28-2005, 12:31 AM
  5. Transmission Drain/Fill bolt?
    By cervy in forum Protege5
    Last Post: 08-06-2004, 06:13 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
