Page 10 of 10 FirstFirst ... 8910
Results 136 to 142 of 142
Thread: ATF Drain/Fill
  1. #136
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,748
    Blog Entries
    6
    IIRC more fluid will be resting in the pan while engine is off than on. I suppose this is why you have to always check level with engine running . That is what I have seen on my GX anyways.
    '15 CX-5 GT 2.5L w/tech package - 49K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  2. #137
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,389
    Arrow ATF Drain/Fill
    Quote Originally Posted by Triton46 View Post
    Good points. My initial reading from the ATF dipstick was at the second "2" on the 122 with the car warmed up and the engine off. It would be interesting to hear, on a properly measured fill, what the reading from the ATF dipstick was with engine running and not running. I did not see any frothing or bubbles on the dipstick which is usually an indication of an overfill.
    Like ColoradoDriver said, you have to keep the engine idling while taking the read on ATF level. Your read was high is because your engine is not idling. The main concern is under-fill not the over-fill, as many have found the factory ATF level is low. If you use the same volume of drained out ATF to refill, chances are you may under-fill the ATF as 3.5 quarts seem a bit low to refill. 3.7 ~ 3.8 quarts are more or less the right volume.
  3. #138
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,389
    Hete is ATF level measurement procedure from Mazda factory service manual:
    Quote Originally Posted by yrwei52 View Post
    Nice!
    ATF level should be at the central marker area on the dipstick at 122F while the engine is running. Make sure to shift into all possible gears during the warm-up.
    Judging by the color of your drained ATF, I may consider another drain-and-fill if I were you.
    Attachment 219691
  4. #139
    Registered Member Triton46's Avatar
    2013 Mazda CX-5 GT
    Join Date
    Nov 2009
    Posts
    168
    I pulled the inspection plate/cap under the car when I got home today from work (10 mile drive) and removed the dipstick while the car was still running (and warmed up). It was right on the center block (middle) of the dipstick. After cleaning it off and reinserting, it showed again to be in the center.
  5. #140
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,389
    From your description I do believe your ATF level is a bit low, like it was from factory.
    Like Mazda's factory service manual and ATF dipstick say, you have to measure ATF level with its temperature at 122F. Apparently your ATF temperature could reach 192F when your engine was fully warmed up at the time you took the measurement. ATF expands a lot more than engine oil when their temperatures are getting warmer. That's why all car manufactures will specify ATF temperature when ATF level is measured. Your ATF level is right on the central maker area when ATF was hot, it'd be below that level when ATF is colder at 122F. You need a bit more ATF to bring up thd level at 122F.
  6. #141
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,555
    Let me put it this way. I drained 3.5 quarts and it took 3.7 quarts to get it to the correct level at the correct temperature.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 80k miles
    01/2013 build | 4/20/2013 delivery
  7. #142
    2013 Mazda CX-5 GT
    Join Date
    Nov 2009
    Posts
    168
    Quote Originally Posted by ColoradoDriver View Post
    You guys are extremely patient, this makes total sense. Thank you! I went out to the garage and pulled the inspection plate, removed the ATF dipstick and added 0.2 QTS.
Similar Threads
  1. To the transmission drain & fill folks
    By bullseye in forum CX-9 Engine & Transmission
    Last Post: 03-30-2012, 06:54 PM
  2. Transmission drain and fill plugs
    By BoostedSpd6 in forum Mazda6 Engine & Transmission
    Last Post: 08-26-2007, 04:56 PM
  3. m/t drain plug and fill ???
    By dupakupa in forum Mazda6 Engine & Transmission
    Last Post: 12-18-2006, 04:43 AM
  4. Transaxle drain & fill
    By JFW in forum Mazdaspeed Protege
    Last Post: 03-28-2005, 12:31 AM
  5. Transmission Drain/Fill bolt?
    By cervy in forum Protege5
    Last Post: 08-06-2004, 06:13 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
