Your Best Source for Genuine Mazda Parts!
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 121
Thread: Who is towing with their CX-9?
  1. #46
    Registered Member
    CX9 Luxury 2010 Black
    Join Date
    Dec 2014
    Location
    Australia
    Posts
    9
    Thanks for the feedback, I did my research before dropping $30K (cars expensive in AUS), we see CX9's towing 18 to 20FT boats all around Sydney. My boat is actually 5.5m or 18ft just measured it .
    Viking Bowrider With the 140hp Merc Outbound engine the weight should be 1100KG.
    The trailer is hydraulically braked.
    Towing Capacity of the CX9 Braked is 2000kg so we are all good......i hope....
    http://www.boatpoint.com.au/content/...der-blitz-9387
    I'll have to find the trans cooler, take a look in manual, unless you can direct me ?
    p.s the Brakes are crap even without towing....they need replacing
  2. #47
    6 wagon for life voldsom's Avatar
    2014 Mazda CX-9 AWD GT w/ Tech Package
    Join Date
    Nov 2014
    Location
    Colorado
    Posts
    450
    Hmmm 2000kg (confirmed by Mazda.com.au) ~= 4400 lbs stateside. So indeed the towing capacities are different between the two markets. Wonder if it's something with the vehicle (unlikely) or something with regulations (likely). Sounds like you looked up the specs, but also keep in mind the tongue weight is still only 330lbs ~=150kg.
    2014 Mazda CX-9 GT Tech Package - Meteor Gray Mica (42A)
    2008 Kawasaki Ninja 650R (EX650A) - Kawi Green (777)
    (Sold) 2004 Mazda 6 MTX Wagon - Glacier Silver Metallic (26A) You Will Be Missed
    6Club - http://forum.mazda6club.com/members/74497-voldsom.html
  3. #48
    Registered Member
    Join Date
    Dec 2014
    Location
    Australia
    Posts
    9
    Interesting difference between regions, same chassis, hardware, we only get 3.7L engines over here, not sure what else is available globally.
    The CX9 suffers the boat well (less the earlier commented brakes), no rear end sagging when lowered onto the tow tongue.
    Most of the boats weight is at the rear over the trailer axle.
  4. #49
    Join Date
    Nov 2014
    Location
    Colorado
    Posts
    450
    To comment on the engines, yep. 3.7L Ford Cyclone V6 throughout the globe. Unless anyone has a first model year 2007, which had a 3.5.
  5. #50
    goes to eleven chuyler1's Avatar
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,528
    Quote Originally Posted by voldsom View Post
    It's regulations related to trailer weighting. In the US they recommend a minimum of 10% on the tongue and since Mazda knows it is good for about 350lbs, they rate it for 3,500. In other countries where driving 75-80 mph through cross winds isn't expected, they allow sometimes as little as 5% on the tongue. I've had my camper weighted wrong before...I won't go below 10% ever on the highway.
    I got my car used with 17,000 miles on it. I notice the front rotors were warped and had them replaced under warranty. Before they did that, braking wasn't great but afterwards it was about what I expected for a vehicle this size. Before you go replacing the entire braking system, try out a few different pads to see if you can get the feel you are looking for from the pedal. It's probably more about how the brakes initially grip than about their actual ability to stop. The CX9 rated above average with braking distance when compared against other vehicles in its class. Also, braking feels different based on suspension too. The CX9 is stiff. I drove a Hyundai Santa Fe rental a few weeks ago and the brakes were very touchy causing the car to nose dive under hard braking. The CX9 never does that. I think it was just the soft suspension that made the brake pedal feel more responsive than it actually was.
  6. #51
    Smokeycx9
    Mazda CX9 Touring
    Join Date
    Feb 2015
    Location
    Walnut Creek
    Posts
    6
    You know it doesn't matter what kind of Vehicle you have. I had an RX7 and many vettes and mustangs now I have a nice 2015 CX9 and its really nice to have forums you learn so much.
    Forums rock!!
    Thanks everyone.
  7. #52
    TomB
    2007 Mazda CX9 Grand Touring AWD
    Join Date
    Jun 2012
    Location
    Houston, TX
    Posts
    13
    So, its been a while since last post, but I've never towed a trailer at 70-75 mph at least not for a consistent period, though CX9 has easily done this, gas mileage and safety sucks at that speed so not my way of towing, my ~325lb tongue weight has never been a problem on my 2009 Starcraft 18RB and 2007 CX9 AWD as far as any sway after 7000 miles of towing, if anything I have smoked Ford Rangers, Ford Explorers, Chevy s-10s, Chevy Astro vans, old 1/2 ton trucks and piece of shits Trailer Blazers etc on plenty of back country roads in Texas. Would not consider any of those vehicles for even safe daily drivers. The CX9 has a GCWR of some 10300lbs everywhere but the US, Vehicles are no different, than US spec, so towing 8750lb combined trailer is a no brainer, NOT even considering below axles max loads, hitch weights etc. I tow at ~5600lbs CX9 controlling 3400lbs with now problems. Same horsepower, heavier tow vehicle (Dodge Ram 1500 V6) has 6500lbtow rating / Truck brakes and handling much worse than modern SUV. I know from driving and comparison!!!! As a final note, my friend 2014 Audi A8lL has ~120lbs more payload than my father in-laws 2014b Ford EXL? F150 crew cab 4wd ecoboost, how pathetic is that, not even considering, turbo 4.0 liter V8 horsepower and break advantage to Audi A8 versus 3.5liter f150 v6TT 150!!!. Noting Audi A8 has a ~5000lb towing capacity in Germany!!!!!!!
  8. #53
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,528
    That's quite a run-on sentence and I'm having trouble making sense of it all. What is the trailer weight and tongue weight of what you have been towing?
    As I have stated before, tow ratings are often different in other countries because of the laws regarding tongue weight. In the US, your suspension and hitch must be equipped to handle 10% of the weight of the trailer. In the case of the CX9, that is 350lbs (for the vehicle) and 400lbs (for the Curt class 3 hitch or equivalent). If you are in a country such as Australia where only 7.5% of the trailer weight must be on the tongue you can haul more weight because 350 is 7.5% of 4,600lbs vs 350 being 10% of 3,500 lbs. They also specify in their ratings that trailer brakes are mandatory for weights over 1,500lbs, a distinction that they don't make in the U.S.
    Trucks with the same horse power as your CX9 can haul more simply because they can support more weight on the tongue. They either have frame-on body designs that can withstand the torque applied by a weight distribution hitch or they have adjustable suspensions that can alter ride height based on load. They also have longer wheel bases with rear tires positioned closer to the hitch to properly distribute weight.
    If you are towing more than double the rated weight (I'm looking that that 8750lb number you threw in there), you are in serious danger of causing an accident. You may be able to cruise down the highway with ease but if you had to make an emergency stop there is no way the CX9 could withstand the pressure of that tongue bearing down on the back of the vehicle. It could likely lift up the front end under heavy braking. That's a worst case scenario, but more than likely you will just hit the thermal limits of the transmission leading to early failure.
  9. #54
    Nihilus
    2009 Mazda CX-9 Touring
    Join Date
    Mar 2016
    Location
    Fayetteville, NC
    Posts
    13
    Hi all,
    In a couple of weeks, I will be towing a 5x10' Uhaul trailer with my "new" 2009 CX-9 through the Appalachian Mountains. I have added a Curt Class III Hitch and Trailer Wiring Harness as the vehicle did not come with any. I have heard that the Cx-9 trucks that come with a hitch have a different ECU flash. Is there any way I can reflash my truck and is it worth the effort? I know these drive trains are weak and I just want to help it any way I can. Thanks in advance.
  10. #55
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,528
    There is no reflash that I am aware of, but the AWD models which come with a factory transmission cooler may be programmed differently from the factory. Basically, if you have AWD you are good to go.
    Sent from my iPhone using Tapatalk
  11. #56
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,046
    Towing prep for 2009 has a different radiator and adds external transmission cooler in addition to the trailer wiring. Not sure about transmission programming but I'd be more concerned about the brakes. Use manual shifting going downhill to try and save the brakes. I towed the largest uhaul trailer they make from Erie, PA to central KY and even with being careful I still roasted my brakes. Needed front rotors and pads afterwards. And mine has the oem towing equipment.
    08' CX-9 GT FWD
    Gray Mica with Black Interior
    Nav/Bose/Sunroof/Bluetooth Phone/Rack&Crossbars/BSM/Pwr Lift/Homelink Mirror/Tow Pkg/All Weather Rear Mats
    K&N drop-in filter/Centric E-Coated rotors & Centric Posi-Quiet Ceramics /Yakima ForkLift Bike Tray / Weathertech front mats
    Tires: Nitto NT850+ CUV
    Oil: Mobile One Full Synth & Mobile One Extended Performance filter
    Problems to date: Blower motor relays replaced once, intake manifold rear brace was missing from factory build, headlamp motors are dying,
    windshield wiper plastic cap broken.
    Mileage: 94k Jan/2017
    Job: Auto Physical Damage Adjuster
  12. #57
    Nihilus
    Join Date
    Mar 2016
    Location
    Fayetteville, NC
    Posts
    13
    Yep, AWD.
    Thanks for the tip on downshifting. Didn't know the brakes were that weak. I will keep it in a lower gear for sure when on I-64 in WV.
  13. #58
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,528
    If the trailer doesn't have brakes you do need to be careful. Rotors will warp if hot pads stay in one place for too long. After hard braking, try to keep rolling. In traffic, leave a gap to avoid hard braking and constant stopping. The other cause of warped rotors is improperly torqued lug nuts so it's always good to check them after a rotation.
  14. #59
    Nihilus
    Join Date
    Mar 2016
    Location
    Fayetteville, NC
    Posts
    13
    I just did a long round trip tow from NC to WI with a 5x8 U haul. I got brand new brakes and rotors before I left.
    NC to WI with empty trailer (about 1000 lbs):
    First off, this vehicle REALLY needs a tow/haul mode. I used manual mode and kept it in 5th gear. This transmission always wants to shift into 6th and I can't stand it.
    I recorded mpg there and back. I always used 89 octane unless stated. Most fill ups were 18-19 gallons.
    With the trailer empty, I got: NC to WV, 14.7 MPG; WV to Ohio, 12.5 mpg; Ohio to Ill, 13.3 mpg (93 octane)
    I used Drive through indiana and the truck was in 6th most of the time.
    WI to NC with trailer PACKED to the brim (2500 lbs?):
    I wanted a lot of tongue weight and may have gone overboard. My wife needed to stand on the back for me to lift it off of the hitch. I used Manual mode the entire time and did not want to screw around with drive.
    I would stay in 5th and on the bigger hills I would shift to 4th as soon as I felt it struggle even a little. It worked great since I could keep my momentum just fine. I tested it with Drive and it really sucks. It would stay in 5th until it was exhausted with momentum being lost, and then it would SLAM it in 3rd gear. It seems very inefficient. On the longer steeper mountains, I manually shifted to 3rd a couple of times.
    This seems terrible for the transmission and less efficient. I get the feeling that this engine hates being dogged out in low RPMs. On the longer and steeper mountain passes, I manually shifted to 3rd a couple of times.
    With trailer full I got: WI to Il, 13.9 MPG (half the tank was 91 octane ethanol-free); Il to IN, 12.4 mpg, IN to Oh, 13.9 mpg, OH to WV, 13.0 mpg, WV to NC 13.9 mpg
    Overall, very happy. The truck did great with that size trailer. Manually shifting into 4th down the mountain passes really saved my brakes. Manual mode kinda sucks, because it won't downshift for you either. I really think this truck would do better on fuel if the Transmission wouldn't be so damn lazy, even unloaded. It wants to shift into 6th gear just above 40 MPH. I really wish they had a tune for these things. It would be more capable, your transmission would last longer and you would get BETTER mpg. Right now, I am manually shifting and keeping the RPMs above 1700 unloaded to see how mileage is.
  15. #60
    2013 CX9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,528
    That sounds on par with my towing experiences. It'll drive at 65-70 mph in 6th but any hint of an incline and you'll see the revs creep up as it engages the torque converter. It won't lockout and stay locked out, even when in manual mode. I pretty much used manual mode in 5th gear for the highway and when I saw the revs jump I knew it was time to downshift. ddly, it does better at higher speeds sinc
    My only question to you, why are you bothering with 93 octane? Unless you have a turbo, 87 is fine.
Similar Threads
  1. towing
    By bgibb68 in forum Protege5
    Last Post: 08-20-2010, 04:24 PM
  2. Towing w 07 GT AWD
    By SteveG66 in forum CX-9 Lounge
    Last Post: 05-31-2010, 01:57 AM
  3. Towing?
    By lynn02 in forum CX-9 Engine & Transmission
    Last Post: 06-29-2009, 05:52 PM
  4. CX-7 Towing?
    By mirt in forum Mazda CX-7
    Last Post: 07-23-2006, 02:15 AM
  5. Towing
    By smimotorsports in forum Protege5
    Last Post: 09-14-2005, 08:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
