All New Power Series 3″ Intake for Mazdaspeed3
CorkSport
2010 Mazdaspeed 3
Authorized Vendor
All Mazdas!
We are happy to announce our 3 inch intake for the Mazdaspeed 3. It is a bolt in for the 2010-2013 model MPS 3.
Designed Specifically for Mazda: All CorkSport parts have been designed and tested specifically for Mazdas.
True 3" MAF: Machined with a True 3" inside diameter MAF.
Turbo Inlet Pipe: A precision high polished 3" aluminum turbo inlet pipe..
Velocity Stack Design: Smooths the incoming air flow and increases the flow rate of air and reduces turbulence.
Durable Dry Flow Air Filter: Reusable and water resistant, this unique non-woven filter media does not require oil to filter and trap dirt and actually sheds dirt under engine vibration unlike cotton-gauze which holds contaminates until you clean the filter.
Custom Reinforced Silicone Connectors: Constructed from multi-layer nylon braid to provide more strength and power and a smooth internal transition for less turbulence and optimal flow.
Upgraded Turbos: Highly recommended for Mazdaspeeds with upgraded turbos.
Fitment for the 2007-2009 Mazdaspeed 3 and 2006-2007 Mazdaspeed 6 must make battery or ECU modifications for fitment.
The intake is $299.99 and a link for the product is here
