My left lower ball joint has gone bad and I can't get the old one loose from the wheel hub. I've tried a pickle fork and a BF hammer but I can't get it to break loose. My old ford escort had a trick where you had to put the fork in at a certain angle then pop the top of the shaft while you pried on the fork. Does anyone know if there's a trick like that on the M2? I'd appreciate any advice you have to give.
