Ok so here is the story, I kept having a cylinder 4 misfire and ended up bringing it to my "local sketchy mechanic" and these guys said they redid a circuit somewhere. (not sure what they meant of that) got the car back and it pulled the same code again. Brought it back to them and they said that the WGA was not fully opening. After about 2 weeks of leaving the car with them, they placed 1 zip tie to "help the management of pipe routing" and it was still giving the same issue.
So i bring it home and was pissed about the whole scenario so I decided to wire my fuel controller. Ran fine for the whole night. I get into my car and it did not start, turns out their "circuit repair" was by splicing two wires together under my driver side and left it unhooked. if the two wires were not touching the car would not start. So i wire these two wires together and it seemed to run fine.
Last week i decided to replace the airbox with a cone filter I had laying around. Ran fine for 3 days then all of a sudden coming home I had to push the car back due to it idling rough and stalling/killing. So i unplug my MAF and yay it idles, however as soon as i give it throttle it bogs down. So thinking this is the issue, I buy a re manufactured MAF from Rockauto (sorry if there is a rule about listing outside sources) It came in tonight and now the issue still is here. I unplug the maf start the car up and it idles. As soon as i plug the Maf in the car sputters/stalls and dies. Do i have a faulty Remanned Maf? or is there something else going on? I have tried the stock airbox setup as well. It is still a no go. I just replaced the plugs and plug wires also so i don't think that would be an issue. Could a bad coilpack be causing this issue to happen? I am getting the P0102 code from the torque app. This car seems to have too many issues that are "hidden" and its getting really annoying since ive had the car for 3 months and have driven maybe 500 miles due to its issues. Please help as i am about to just give up on this lemon.
