Starting my own thread so others can read, share, and hopefully learn.
At around 48K on our 2010 CX-9 AWD started leaking dark colored, sort of graphite gray fluid from under the front of the car just in front of the driver side foot well. I changed the oil myself and looked under there noting the dark greasy stuff was all over the mounts on that side of the car.
After reading a few threads here about this same issue being the AWD transfer case, and on the recommendation from another forum member, I took the car to local dealer for a look. I have around 10K left on warranty.
Sure enough the transfer case was leaking. Dealer ordered one from Mazda and replaced it under warranty in a couple days and gave me the car back on a Friday.
My wife drove it from the dealership so I didn't get to talk to her about it until we got home. She said it sounded funny but seemed to drive fine.
The next day, I took it for a spin and noted the following:
So I'm taking it back to the dealer for another look next week and I'll report my experience.
Anybody go through two transfer cases in a short period of time or get a bad unit out the gate?
- Slight rattle or grumbling from the area where the transfer case is located at light throttle, just off idle
- This noise was most prevelant when the car was cold. As it warmed up, it would go away ( initially )
- After a week, the noise was worse and didn't go away after warmup.
- The 3.7 motor is much louder and sounds more loaded down at mid range RPM under accelleration. It's really noticable.
- One week later and the new case is leaking on my floor.
