They are not going to do anything since the warranty is only 90 days even though the lights only have about 100 hours on them I would not want a replacement anyway. If you have a problem with the light falling into the headlight assembly their solution is to remove the entire headlight and shake it to get the led portion out. I can tell you aside from the issue of removing the headlight the hole is too small to simply shake out the part. I wish there was a way to make everyone who bought these lights aware of the problem because I am certain that this is not an isolated problem. The adhesive that holds the led array to the base fails, maybe because of the heat or vibration.
