I had the clutch replaced this last spring/summer at a private repair shop that I've used a number of times. A couple days ago, my wife couldn't get the car started and thought the battery was dead. It wasn't. The clutch switch was not being actuated when the clutch pedal was pressed to the floor and the car wouldn't start. Once I took a look, I saw that the clutch pedal would stick to the floor and would only come up when I pulled it back. I'd press it again and the same thing would happen. I started it in first gear and drove home.
Today, I saw fluid around the slave cylinder so I bought a new one and was going to put it in, but noticed what I think is the real problem....the release arm is floppy. I can move it back/forth without any resistance. It seems that something inside the transmission/clutch is broken or out of whack. Here's a video of what it looks like:
I think the guy I had replace the clutch may have gone out of business - I can't reach him. Could this be an 'easy' fix? I'm pretty mechanical, though lack multiple tranny jacks, engine lifts, etc. I have hand tools, jack stands, etc. No air tools. Or, is this more of a 'real mechanic' type fix?
Thanks.
Thanks.
