Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Fog lights not working?
  1. #1
    Registered Member vw2p5's Avatar
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Okay so I did the fogs on with the parking lights, everything was working fine for a while. Then last winter the fogs stopped working. Then in the spring they started working agaîn. Now they aren't working again. Pull the fogs out and switched them with a newer pair I had, still nothing checked the fuse, checked the relay, checked wiring everything seems to be intacted. Checked to see if I had 12 volts at the harness where the fogs plug into the wire harness and there didn't seem to be 12 volts there. Any suggestion or help would be greatly appreciated.
    Thanks,
    Chris
  2. #2
    MartyBalls Balls's Avatar
    03 Protege5
    Join Date
    Apr 2008
    Location
    Rochester, NY
    Posts
    349
    Check for corrosion in the wires. I had a similar problem a few years ago. I rewired them and haven't had any issues since.
  3. #3
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Quote Originally Posted by Balls View Post
    My wired look good. I am thinking I might have a bad switch. When I push the button in to turn the fog lights on, I don't hear the relay engage. But when I disconnect the wire and touch the wires together at the relay I can hear it clicking.
  4. #4
    The Pizza Guy esnave09's Avatar
    2002.5 Mazda Protege5
    Join Date
    May 2013
    Location
    Mankato, MN
    Posts
    533
    I would think that's what it is. I know since I did the mod my light on the switch isn't working. Hopefully mine doesn't quit on me. That mod comes in handy with really thick fog on pitch black roads.
  5. #5
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Quote Originally Posted by esnave09 View Post
    Yeah man, I'm gonna replace the switch and see if that doesn't fix the problem. It is a handy little mod.
  6. #6
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Well I am still having an issue with these damn fog lights. Installed a different switch, still no fog lights and the light on the switch doesn't light up anymore. Any ideas? Thanks.
  7. #7
    Registered Member
    Protege5
    Join Date
    Nov 2012
    Location
    Michigan
    Posts
    8
    Quote Originally Posted by vw2p5 View Post
    Are your bright lights "on?" Sounds silly I know but happened to me. Was wondering why all of a sudden my fogs wernt working . I had, as well, wired them to the parking lights so not having the headlights on didn't illuminate the high beam indicator on the dash (or turn the high beams on). So you could have them switched on without having any indication.
  8. #8
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    No, my brights aren't on, but my fog light switch isn't even illuminated anymore. So I don't think I am getting power to the switch. I am clueless to what happened
  9. #9
    Registered Member
    Protege5
    Join Date
    Nov 2012
    Location
    Michigan
    Posts
    8
    Sounds like you are pretty competent when it comes to wiring, so the only thing I can suggest would be start at the lights and work your way back. I haven't been into mine enough to suggest any specifics and I don't have a diagram on me either. When you checked for 12v at the plug did you use an independent good ground? If you probed both terminals at the plug you could be getting 12v and not know it if you had a bad ground. If no power there I assume the relay is next in line? Check for power coming into the relay again with an independent good ground source. If you have power there then ground out the relay and check if you have lights. If still no lights try bypassing the relay then you should have fogs and the relay is bad. If you don't have power coming into the relay to begin with then move on to the switch. If I recall this is where it gets hard without a diagram I want to say there are more than a few wires there but the practice is the same. Check for power in and out. Try grounding out the switch and/or bypassing to determine weather or not the switch is bad. Keep working your way back all the way to the fuse. Something could be messed up in the headlight switch too.
    If you think the cold temps has an effect then you could have a loose connection somewhere so that when the wire shrinks in the cold it actually unplugs itself.
    Good luck hope this helps.
    Oh it might also help to use a volt meter instead of just a test light to confirm you have the full 12v and are not getting a voltage drop.
  10. #10
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Matt, once this weather breaks I am going to go out there and trouble shoot those fog lights untill they are working again. I'm not sure if I was using a good enough ground but I will make sure the next time. I have a pretty nice multimeter. Thanks again for help... Happy holidays.
  11. #11
    Registered Member
    Mazda, 2003 Protege5 Sport
    Join Date
    Oct 2013
    Location
    Minnesota
    Posts
    58
    right now I am having the problem of one of the lights not working I just changed out the bulb plugged it in a get nothing not sure when I got in my crash some thing may have been cut? but everything else work that on that wire.. So I am not sure whats up...
  12. #12
    Registered Member Dominic Elias's Avatar
    2002 Mazda Protege5
    Join Date
    Dec 2013
    Location
    Toronto, Canada
    Posts
    37
    Broke my foglight bolt taking it out, so now im down a light, im not even gonna touch the other one in case it breaks too. If it does im screwed because my CAI filter is right behind the foglight
  13. #13
    Join Date
    May 2007
    Location
    Painesville, Oh
    Posts
    1,005
    Okay, so I figured out my fog light issue.. I checked for 12 volts at the fogs, and nothing. So I took on lead touched it to the fog harness, and one to the frame, then I got 12 volts. So then I checked the connections where the 2 harnesses clip together. And the middle pin was all bunt up and wasn't making a good connection. So I cleaned it up a bit and connected the 2 clips. It made a solid connection because my fog lights are now working, and I plan on changing the clips with new ones so this problem does not keep happening. Does anyone have a clue on what would cause the harness to burn up like that? Thanks everyone for the help.
  14. #14
    Join Date
    May 2013
    Location
    Mankato, MN
    Posts
    533
    I wanna know about this too. My drivers side low beam has that issue too, and it's really annoying. Maybe it's from current surges or something?
  15. #15
    Registered Member
    2003 mazda protege5
    Join Date
    Sep 2016
    Location
    Az
    Posts
    2
    I too have this issue with my fog lamps.
    1st- changed out bulbs( old ones looked fine,but swapped anyways)
    No surprise went to test them before reinstalling. No light!
    2nd -tested for 12v at connectors.(w/know good ground) I got a reading of 0.02v on both lamp connections.
    3rd- checked relays..all good.
    4th- disconnected switch and tested for power at connector. 4 pins. One was ground. Two had consant 12v.( checked with meter and test light.) and the last one was power to ground( used test light hooked to ground and got 12v at that pin. Still confused. Bad switch or a voltage drop? Too late to continue work in the am. I will take pictures and post a wire diagram and switch diagram.
Similar Threads
  1. dash lights not working
    By TSPOON in forum MSP Problems
    Last Post: 03-01-2013, 12:28 AM
  2. Fog lights Not working
    By Aloger in forum Protege5
    Last Post: 11-30-2008, 11:39 PM
  3. Brake lights not working - help please!
    By coldie123 in forum Protege5
    Last Post: 04-07-2006, 09:18 PM
  4. Fog Lights not working
    By Kooldino in forum Mazda How-To
    Last Post: 04-02-2004, 09:40 PM
  5. fog lights not working
    By joefufu in forum Mazdaspeed Protege
    Last Post: 06-21-2003, 05:59 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
