Here are the test conditions on AllData.
DTC P0126
-If the ECT signal never exceeds 160F after the engine starts for a specified period, PCM determines the coolant thermostat is stuck open.
Monitoring Conditions
-IAT above 14F
Vehicle Speed over 3.7 mph
Test period varies based on temp. For example:
If IAT is 14F, test period is 20 minutes.
If IAT is 86F, test period is only 8 minutes.
So it only runs the test if its warmer than 14 degrees, and it only runs the test if you are moving.
PS. I did the job. It really wasnt that bad, other than all the screws for the bottom cover were totally rusted and the clips broken, so I had to cut it off.
A couple of tips...
- Dont remove the radiator drain plug completely, the coolant shoots everywhere. Just unscrew it until you see some fluid start dripping straight down.
- when you remove any of the hoses, expect coolant to come out. Also, when you take off the thermostat, another large volume of coolant is going to come out. Be prepared with your pan.
- Definitely remove the tensioner. Its really easy, and it gives you precious inches for wrench swing. Make sure you pay close attention to how the belt sits on the on the pulleys before you remove it
If I didnt have to battle with my bottom plastic cover, this would have been a 1 hour job, 2 if you include burping the air bubbles out of the system after you refill the coolant.
Thanks for all your support guys!
