Any advice is greatly appreciated...
Car overheats with normal driving, can avoid this by running the car's heater full blast. No visible coolant leaks, coolant level is fine and radiator cap is under a year old. It seems like the two fans behind the radiator do not come on at anytime (car on or off). They will by turning on the A/C, so at least i know the fans function.
Since the fans run with the AC turned on, does that prove the 30A "Cooling fan" fuse is good? Any suggestions for what else i can check?
