Loose CX-5 Spoiler Inserts
Today, I have looked at my rear spoiler(I remember, somebody pointed out a couple of days ago, about this noise coming from the back, but I can't find that thread), because I was hearing some weird noises coming from the rear.
I have removed the two rubber plugs, behind the spoiler and to my surprise, on the left side, the nut it was gone, I couldn't find it and on the right it was loose, I could turn it with my fingers.
I would suggest to everybody, to look at your spoilers.
Same thing here. I was hearing a rattling sound that was driving me crazy which led me to this post and sure enough it was a loose driver side spoiler nut - actually the nut came off the bolt and was rattling around inside the black plastic cover; the passenger side nut was still firmly attached to the bolt as were the 2 center nuts under the long black plastic trim piece.
My 2 black plastic triangular outside spoiler inserts are still loose so will try the double sided tape trick to see if that will stop the noise as well.
Reposting these member pics for convenience:
https://www.mazdas247.com/forum/attachment.php?attachmentid=204823&d=1382248555
https://www.mazdas247.com/forum/attachment.php?attachmentid=204816&d=1382239507
https://i583.photobucket.com/albums...600x450-1380791154sxerz583232_zps7e390d19.jpg
http://www.mcx5.org/rear_spoiler_removal_installation-463.html
https://www.jimellismazdaparts.com/...make=995&ukey_model=20165&ukey_category=20229
https://photos.google.com/share/AF1...?key=SHF6UVFDQ2RtTS0ydGt1b3NfQnRhWVowVUpPMm13
https://photos.google.com/share/AF1...?key=WFNBMk03bmR1b2VyS0RPR3VoSWtUV0g0UXU0Q1RB
https://photos.google.com/share/AF1...?key=SS1YQW1pNTZ1WGdBQkItSnZ4SEhraTRKZDc2UFN3
https://photos.google.com/share/AF1...?key=MFZlZmJXYUlXZ19nRWVkY2hydXZ0SUtNdm5wYkZR
TSB for rear hatch alignment: https://redirect.viglink.com/?forma...ww.rx8club.com/attachments/g...-over-bump-pdf
I just tightened down all 4 of the accessible spoiler nuts but I find that the plastic triangles are loose. From what I am reading, the only way to tighten them is to remove the full rear spoiler...Tighten the screws and reapply the double sided tape so that it can’t come loose again?
Latest posts
