Hi there, I recently purchased a used 2007 Mazda 5 Touring from an area dealership. So far, I love the car, but I noticed some behavior from the cooling fan that isn't quite right. I was wondering if anyone on here might be able to help.
When we bought the car, the cooling fan would run when the engine was cold and turn off when the air conditioning was turned on. It seemed like it should be the opposite. We took it into the local Mazda dealer, and after looking at it for an hour they said the wiring was wrong and it might have damaged the fan control module (they weren't 100% certain). They wanted over $500 to replace the module, which seemed like a lot. In the meantime, they said they switched around some wiring so that the fan would run all the time (when the vehicle is on) to at least protect the engine when the AC was on. At the time, it sounded like they corrected whatever was wrong with the wiring and it just needed a new fan control module.
I saw that I could get a fan control module on Ebay for $130. That sounded a lot better than the $500. I swapped it in, but no change. That's when it occurred to me that the dealer's wiring might not have been correct and maybe I need to look into that. I realize there are some sensors (engine coolant temp, crankshaft position, throttle position) and a switch (refrigerant pressure) that affect the signal to the module that may need to be looked into as well, but given the history of the wiring, it seems like I should rule that out first.
In any case, my fan now runs continuously (when the vehicle is on) and I basically have two questions:
1. Can anyone with a similar Mazda 5 tell me what their wiring into the fan control module looks like? There's a 3-prong harness and a 2-prong harness. My understanding is the 3-prong provides power and a signal to the fan control module, and the 2-prong provides variable power to the fan motor. I've attached a photo of the harnesses connected to the module with labels of what I learned using my multimeter. Does this seem right? I looked at some wiring diagrams I found online to check it against, but it was unclear what direction they were referencing when they looked at a harness.
2. The fan blows air toward the radiator (toward the front of the vehicle). See attached photo. Is this correct? It seems like it should blow away from the radiator (away from the front of the vehicle) as to be in the same direction as the airflow while driving. It seems like the airflows would fight each other when the fan is running and I'm driving. Maybe I'm mistaken on that, though.
The biggest reason I'd like to fix this is the fan is quite loud. Not in a way that there is something mechanically wrong with the fan. It's just the motor and fan itself. It's about as loud as the cooling fans of some large work vans I've driven, and I feel bad when I'm driving near pedestrians or that I know my neighbors can hear me drive down the block.
Maybe I just need to bite the bullet and take it back in to the dealer. Just worried they're going to charge the $500 for the module, find out it's something else, and it's going to end up being $1000. Any ideas, confirmations on fan rotation direction, pictures of your wiring, etc would be much appreciated. I looked elsewhere around the forum and online and haven't found anything exactly like this, but I'd be happy to be corrected if you can point me toward something I haven't found.
Thanks in advance!
Thanks in advance!
