Hello...new to the forum..
My 2008 CX-9 Touring AWD is due for rear differential oil change. The manual specifies "API Service GL-5 (SAE 80W-90)". Can you recommend any brand name that you have used in this model?
I have found Royal Purple 80W90 at Amazon:
Royal Purple 11687 HPM Gear Lube 80W90 High Performance Synthetic Marine Gear Lubricant - 1 Quart
https://www.amazon.com/dp/ (commissions earned)
Can this be used? Is the "Marine" supposed to be better?
Or, should I use 75W-90 rather than 80W-90? Does it matter?
Royal Purple 01300 Max Gear 75W-90 High Performance Synthetic Automotive Gear Oil - 1 Quart
Any other recommendations?
Appreciate any input..thanks!
