Hello-
I'm new here, my apologies if perhaps this should have gone under "Rim & Tire Options", but that thread looked pretty dead. I've got an 07 MS6, all stock. It's my daily driver and I log a lot of miles, approaching 100K. I've already replaced three rims with OEMs over the years, and then I put it on a lift this weekend (I was getting some vibrations, especially under hard braking) and found three of the four rims are significantly bent, so I think it is time for a whole new set, and maybe time to get a away from stock since I've had poor luck with them. I generally baby it, but I drive the city a lot and can't avoid every pothole I guess, but maybe something else would be better? I'm researching wheel options and finding that there is very little out there that matches the 18x7 dimensions of the factory wheels. Tirerack and similar sites have a lot of 18x8 and some 18x7.5. I want to stay as close as possible, so I'm thinking I'll try and go with an 18x7.5 wheel and keep running 215/45/18 tires. Most sites recommend 225/40/18, but I don't want any chance of anything rubbing.
Does anyone have any thoughts on how the 215's are on the 7.5" inch wheels, or maybe recommended rim in that size? Also, what about offsets? I know the OEM's are 55 (High Positive Offset (HPO) - I think). With the 7.5" wheel do I try and stay at 55 or maybe just a tad less in order to the tire position about how it is now?
Thanks!
Jeff
Thanks!
Jeff
