My radio/cd unit has been in and out for the last year or so, meaning the sound cuts in and out (not the power). I just decided to remove it just to make sure there wasn't a loose connection in the back. When I reconnected, it wouldn't power up at all. I checked all fuses and nothing was thrown.
So I have two questions:
1. Is it possible the disconnecting and reconnecting cause something to short internally? Or other suggestions?
2. I've been searching ebay for OEM radios just in case I my unit is officially dead. And since some of the units are more than I expected to spend, I also searched for Miata, Tribute, Millenia, and MVP. I wasn't surprised to see most of the units across the different models looking similar, and the wiring clip to look the same as well. So my question is are most of these radio/cd units all compatible? (the non-BOSE branding radios). I found the same exact unit as mine on ebay for a Millenia: https://www.ebay.com (commissions earned) But there are a few others for Millenia, MVP, and Miata that I might be interested in, like this one: https://www.ebay.com (commissions earned) . So does anyone know about the cross compatibility for all these similar units?
Thanks!
Thanks!
