Product Release! CorkSport 2010-2013 Mazdaspeed3 / Mazda3 Hood Strut Lift Kit
CorkSport
2010 Mazdaspeed 3
Authorized Vendor
All Mazdas!
Lift your Hood with just the flick of a wrist. Thanks to gas-powered struts the CorkSport Hood Lift Kit will raise your Mazdaspeed 3 hood on its own power once you get it past halfway. Then, just like magic, the hood will stay up for as long as you want. Of course, while the hood is lifted you will have extra room to maneuver thanks to the conveniently located struts. Without the poorly located hood prop-rod blocking your access to the hood, you can now access the entire engine bay as readily as you can find a coffee shop in Seattle.
The CorkSport Hood Strut Lift Kit requires no drilling or modifying to install. With bolt-in compatibility and a short install process, you will be upgraded in no time.
The CorkSport 2010-2013 Mazdaspeed 3 Hood Strut Lift Kit is available online for $109.99. Visit the listing at: http://www.corksport.com/corksport-2010-2013-mazdaspeed-3-hood-strut-lift-kit.html
This kit fits all models of 2010-2013 Mazda 3 including Skyactiv.
Check out a video of the Hood Strut Kit in use here: http://youtu.be/FtQ30mpmDXw
