VersaTuner - tuning software for Mazdas
Results 1 to 15 of 15
Thread: Trouble Filling Gas Tank. Can only fill slowly...
  1. #1
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    93
    I am having a weird issue wherein, once I fill up with about 1.5 gallons, the nozzle disengages and thinks the car is full. Depressing the lever again only causes it to disengage immediately and only puts a few drops in each time. However, if I put gas in slowly, it will fill up.
    I tried taking some of the hoses off around the one way vent valve and blew compressed air through them, but it didn't help. I also blew some compressed air through the one way valve (not against the valve, for risk of damaging it). I can't seem to find an obstruction and the vent tubing doesn't appear to be damaged or kinked. I can't seem to determine how to blow air through the actual vent hose that goes to the filler cap area since air doesn't seem to come out the tiny hole at the top when I do experiment with blowing air up from the bottom.
    Does anyone have any ideas that might be particular to our P5s that might help me to solve this?
    Regards,
    Zach
    2002 Protege5
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,521
    Check all the components circled in red for blockage or being filled with gas.
    Apparently if you fill up the gas tank too much, gas can flow backwards down the vent tube and fill up the cylindrical canister preventing it from venting.
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,521
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,521
  5. #5
    Registered Member Brian_K's Avatar
    Protege5
    Join Date
    Jul 2009
    Location
    Orange County, CA
    Posts
    1,573
    That black filter canister pcb circled above is clogged with fuel. Just remove it and you'll be able to fill up gas normally again
  6. #6
    Registered Member rit14623's Avatar
    2002 Mazda Protege5
    Join Date
    Aug 2005
    Location
    Richmond, VA
    Posts
    421
    Where is that area 'circled in red' in the car?
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,521
    Quote Originally Posted by rit14623 View Post
    It's up underneath just behind the rear bumper. You can see some of it by just looking underneath without lifting the car.
  8. #8
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    93
    Ok, so I disconnected the charcoal cannister to see if I could fill the car up properly and I had no problems, so I imagine that there is an issue with the cannister. I noticed some gas came spilling out one of the hoses that I disconnected from the cannister. I only expected vapor to come out, so that was somewhat surprising. Does gas normally flow through the cannister like this? I thought a gas soaked cannister was bad.
    Regards,
    Zach
  9. #9
    Registered Member kms1990's Avatar
    2011 mazda 3 hatchback GT
    Join Date
    Jun 2013
    Location
    Fort Worth, TX
    Posts
    932
    that gas soaked canister sounds like your issue to me. it cannot vent correctly and so shuts off on you. this is caused by overfilling too much too often
    Disturbed "is she not right, is she insane?"
  10. #10
    Registered Member
    Mazda, Protege5 2002
    Join Date
    Aug 2008
    Location
    Orange County
    Posts
    476
    never top off. no reason for it
  11. #11
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    93
    I only fill my tank when 1/4 remains. I've never topped off. My concern is that if I replace the canister that the new one will also get soaked since gas leaked out of one of the disconnected hoses when I was attempting to fill it without the current canister hooked up. But if the consensus is that the canister is the problem, I guess I will have to try replacing it and see if the new one lasts.
  12. #12
    Registered Member
    Protege5
    Join Date
    Jun 2006
    Location
    Denver, CO
    Posts
    93
    Ok, so I replaced the canister and that allowed me to fill the tank up to 3/4 full, but it stopped at that. I figured that was an improvement, but the next time I filled up from 1/4 full the problem returned and I still have to fill it super slowly. So the problem must be something other than that canister. Frustrating.
  13. #13
    speedless :(
    2003 P5, 2013 BRZ
    Join Date
    Jun 2011
    Location
    Monroe, WA
    Posts
    37
    I have the same issue in my wifes P5, curious to see if you find anything else that might be the cause.
  14. #14
    Registered Member
    97camaroSS e30 318is Spicy #1348
    Join Date
    Aug 2012
    Location
    Manhattan Kansas
    Posts
    119
    Anyone have the part number for that evap canister located in the back drivers side wheel well?
  15. #15
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,521
    Photobucket stole my pictures but I've got this.
Similar Threads
  1. Problem filling gas tank
    By golftango in forum Mazda5 Engine & Transmission
    Last Post: 01-07-2014, 12:07 AM
  2. Anyone Else Have Trouble Filling the 2 w/ Gas (???)
    By EconoBox in forum Mazda2 Lounge
    Last Post: 08-03-2012, 01:38 PM
  3. Replies: 3
    Last Post: 03-13-2011, 10:05 AM
  4. Gas tank only filling up halfway
    By rayray2030 in forum Protege5
    Last Post: 12-29-2005, 08:00 PM
  5. OVER FILLING GAS TANK
    By <MP3110> in forum Mazda MP3
    Last Post: 02-28-2002, 09:07 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
