OK,... So I'm a little confused,... I thought from reading that link above, that the PCV could definitely be a "root cause":
"Most engines employ a PCV valve at the point where fumes are drawn out of the engine. The PCV valve serves several functions. At an idle, engine vacuum is very high, around 16 to 20 inches. This high vacuum would tend to draw oil as well as fumes from the engine. The PCV valve acts as a buffer against oil being drawn out and regulates the amount of vacuum applied to the engine.
Because the engine idles at low speed there is a relatively small amount of fuel and air traveling through the intake. If the PCV valve did not regulate flow, the engine would act like it had a vacuum leak. Air flowing into the intake might cause the engine to lean out [too much air in relation to the fuel] and misfire. At an idle, the PCV valve restricts air flow, to reduce this problem."
If the PCV valve were stuck open and not restricting airflow properly it may suck all kinds of oil into the intake ??? Our ECU would probably do it's best to compensate so we may not misfire ???
I do get how worn rings would put excessive blow-by pressure on the valve and foul it, push oil through it or wreck it quickly though.
I remember one guy said a new PCV valve fixed his problem but just for a short while,... his new valve was probably quickly fouled or stuck.
