Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Full size spare wheel+tire in OEM spare storage?
  1. #1
    CX5 Road Tripper maxwax's Avatar
    2014 Sky Blue Touring AWD
    Join Date
    Jun 2013
    Location
    Denver, Colorado, USA
    Posts
    109
    Subject says it all.
    I've gone on long trips before where I'll be away in remote areas of the USA and away from cities for days. I'd like to get a full size wheel + tire and store it in the space where the OEM spare is at.
    Pardon my ignorance, but I'm assuming the OEM spare is a little smaller and less capable than what's on the wheels now.
    Thanks,
    2014 CX-5 Sky Blue Touring AWD
  2. #2
    Registered Member
    Join Date
    Apr 2013
    Location
    Southern Ontario
    Posts
    124
    As I understand it (from another thread here - I haven't verified the size of the spare) the spare is a full diameter tire (or very close, at least) but is obviously not as wide as a full size wheel + tire. The full size wheel and tire should fit in the hole for the spare, but the spare tire cover isn't going to fit properly.
  3. #3
    MoMo MikeM.'s Avatar
    2013 Mazda CX-5 Touring AWD 2.0L
    Join Date
    Aug 2012
    Location
    NW Washington State, USA
    Posts
    3,970
    Quote Originally Posted by maxwax View Post
    Thanks,
    No doubt that silly looking spare is not as capable as the real deal but I would trust it to get me out of some pretty remote and treacherous places. You just need to go slower when you get to pavement on your way to a tire shop. You might not ever need to use it, quality modern tires are quite reliable when kept properly inflated.
    A full size spare will really impact the functionality of the trunk area.
  4. #4
    Registered Member
    2014 CX-5 Touring AWD, Liquid Silver
    Join Date
    Feb 2013
    Location
    VT/NH
    Posts
    717
    The 'donut' spare tires usually are rated for 50 mph max, and this is stated in large letters on the sidewall. I'm guessing the CX-5 spare has this same rating, but I haven't specifically checked.
  5. #5
    Registered Member RedBaron's Avatar
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    Not sure of the depth of the spare tire well, but from memory I doubt a full wheel would fit without raising the floor panel.
    In any case, I would buy a decent tire plug set and 12v compressor to bring with you. That way you can repair most punctures pretty easily - though always get the tire professionally re-repaired and patched on the inside, when back in 'civilization'!
    You can also use the tire-inflator/sealer cans, but they can have negative long-term effects and I personally wouldn't use them.
  6. #6
    I drink (coffee) & drive. DaddyD's Avatar
    Mazda 2009 CX-9
    Join Date
    Apr 2009
    Location
    Freeport, Long Island, NY- Boating & fishing capital of the East
    Posts
    74
    Quote Originally Posted by MikeM. View Post
    You might not ever need to use it, quality modern tires are quite reliable when kept properly inflated..
    True, but still very much vulnerable to the random sharp object. Had to replace (not repair) a tire at just 30,000 miles or so after a screw became embedded in it.
    2009 Stormy Blue Sport
    15May09
    If everyone's thinking alike, someone isn't thinking.
  7. #7
    Registered Member
    2014 Mazda CX-5 Touring
    Join Date
    Mar 2013
    Location
    Dacono, CO
    Posts
    142
    Thanks,
    Great question, MaxWax.
    Since I'm going on a trip in a week and a half, I thought this required a couple minutes to answer.
    I have snow tires mounted on my stock wheels, and aftermarket 17's that have the stock Geolanders on them, on the car, so it was as simple as grabbing one of my snow tires, popping out the center cap, and tossing it in the trunk to see what the answer is.
    Stock:
    Full Size:
    Unfortunately, the answer is No, you can't put a full size spare, and have a flat lying trunk floor.
    You can screw down the full size wheel using the yellow screw down knob:
    But then you have a floor that looks like this:
    Hope this answers your question Max.
    BC.
  8. #8
    Join Date
    Jun 2013
    Location
    Posts
    109
    Quote Originally Posted by Bladecutter View Post
    BC.
    THANKS! That picture is exactly what I wanted to know. Based on this information I think my approach for a serious road trip might be to pull the stock spare and re-use that space for whatever items I want to bring but don't reasonably expect to use. Not really sure what that would be right now, but basically: use that stock spare space to free up space elsewhere. Then, bring a full size spare in the trunk/boot area along with other items.
    If you have an opportunity, could you take a picture of one of your full sized tires in the trunk area? It would give me, and others, a good visual idea of how much space they take up. I suppose lying flat and packing stuff on top would work and keep the added weight's center of gravity a bit lower, but if I'm really going in a rough terrain, I might stand it up so it's accessible.
    Thanks, again and nice work with the visuals on this post. This was great!
  9. #9
    Wheels, not rims... SayNoToPistons's Avatar
    CX-5 GT AWD w/ Tech, RX-8 GT 6spd w/ 'goodies'
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,774
    Factory spares can actually go through quite a tremendous amount of abuse, even though it is rated for such low speeds. The actual engineered factor of safety is beyond the low rating of ~50 MPH.
    Exhibit A:
    http://www.youtube.com/watch?v=HPh90yNX-mY
    At the same time, don't be one of those idiots that do 70+ MPH on the left lane with a space saver spare on the driving wheel for a weeks worth of daily commute, in which case is front wheels of all CX-5's (front bias on CX-5 AWD).
    2013 Mazda CX-5 Daily - GT, Tech Pack, AWD, Black Mica, Sand/White Interior, LED everrrryyything, Morimoto XB LED Foglights
    2004 Mazda RX-8 Driveway/AutoX Queen - KW Varient 3 Coilovers, Cobb AP + Tune, Progress Tech Sway Bars, Enkei RPF1 + RE11 in 275, Greddy Evo TT Catback, BHR catless midpipe, BHR coils, BHR motor mounts, Racing Beat intake snorkel, AF Short Throw Shifter, etc etc.
  10. #10
    Registered Member
    Join Date
    Apr 2012
    Location
    Canada
    Posts
    188
    As no one else has mentioned it, according to the owners' manual you are NOT to use the standard spare to replace a front wheel; swap the flat front with a good rear and then install the spare in the rear. This should suggest that the spare is sufficiently sub-par that only in the gentlest of conditions should usage be considered.
    Brian
  11. #11
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    Quote Originally Posted by bamirault View Post
    Brian
    All well and good, and I understand the thinking, but that means jacking the car at the good wheel, swapping the tire, unjack, jacking at the BAD wheel, swapping the tire, unjack. Try telling that to someone stopped on the side of a highway with cars whizzing by at 70mph! Agggh!
  12. #12
    Registered Member
    was 175ps Mazda CX-5 Auto AWD Sport Nav, now 190ps DSG Tiguan 4M
    Join Date
    Oct 2012
    Location
    worksop Great Britain
    Posts
    2,321
    According to Mazda the space saver can't be used when towing.
    I've got a full set of 19" wheels with tyres, and intended to use one as a spare, as I tow a 1565kg caravan, in the UK we don't have a spare at all.
    Its a shame the boot floor is raised but I can live with that.
  13. #13
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    Quote Originally Posted by xtrailman View Post
    Can't you put the spare in the 'van?
  14. #14
    Registered Member
    Join Date
    Mar 2013
    Location
    Dacono, CO
    Posts
    142
    Sure, here you go:
    BC.
  15. #15
    Registered Member
    Join Date
    Mar 2013
    Location
    Dacono, CO
    Posts
    142
    Quote Originally Posted by RedBaron View Post
    Honestly, if you're on the side of a major road like that, just swap the spare with the bad tire, drive until the next exit, get off the highway, and do the switch then.
    It actually won't damage the drive train to have the spare tire on the front, since the CX-5 does not have a locking/limited slip front differential.
    I'm not really sure what the warning in the owners manual is about.
    BC.
Similar Threads
  1. Will full size spare fit in the spare tire well?
    By breiland in forum Mazda Protege
    Last Post: 11-14-2010, 04:02 AM
  2. WTB: full-size spare
    By localkineguy in forum Completed Transactions
    Last Post: 08-29-2010, 10:33 PM
  3. WTB: Full-size spare tire
    Last Post: 05-28-2010, 07:02 PM
  4. full size spare?
    By localkineguy in forum Protege5
    Last Post: 04-25-2010, 10:28 PM
  5. spare tire/wheel size?
    By Tzar177 in forum Mazda MP3
    Last Post: 03-04-2007, 06:18 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
