While installing the big c-clip in the hub, I slipped and put a dent in the seal on my new bearing. I decided to try to straighten it out and the whole "seal" popped off. I wasn't impressed with what I saw. The "seal" was nothing more than a dust cap. It was just a flat ring with a bead of rubber on either side. (I forgot to take a picture)
That "seal" isn't going to do squat and I'm fully expecting to have to redo my bearings again in a year or two. I decided to cake both seals with grease before installing it on the car. I know it will attract dust and dirt but I think it will help create a better water barrier.
This is a picture of the old bearings seal. It is a much better design. The metal ring is press fit to the inner race and the rubber part is seated on the outer race. The entire rubber surface rotates on the metal part and there is a stainless steel coil spring to keep the rubber seal tight on the metal ring.
The rust did invade the old bearing eventually (it lasted at least 4 years,... since I bought the car) but it didn't fail until the rust swelled the outside of the ring warping the rubber inside and breaking the seal.
This is yet another example of cheap Ebay crap that isn't up to snuff. (It has the right part number and is listed as a "premium" bearing with a 3 year warranty). I should have spent the extra $30 and bought the SKF bearings from Rockauto (it's the only one that is listed as "sealed",... I'm sure it has a proper seal in it).
This is way too big a job to skimp on parts.
