I recently became the owner of what I thought was a nice '06 Mazda 5 with 126'000 klm. On the test drive I thought it felt like the front right strut was not too good, but otherwise it felt ok to drive. Once I got the van into the workshop for a better look at the brakes and suspension, I realized it was a lot more tired and worn than it felt to drive. After some research here and elsewhere on the internet, I decided it was worth putting the money and time into rebuilding and upgrading both the front and rear suspension systems. I went with BC Racing's kit for the springs and dampers, SPC adjustable rear upper control arms, and mostly Whiteline bushings for the pivots. Unfortunately, none of the polyurethane bushing manufacturer's seem to do all the bushings needed, so I have Powerflex for the rear lower arm outer bushings, and Prothane bushings for the rear trailing arms pivot.
Originally my idea was to just install the springs and dampers, upper control arms, and only replace the lower control arm bushings. What changed my plan was the fact that the pivot bolts that provide toe adjustment for the rear end were completely seized to the steel sleeve within the rubber bushing, therefore a wheel alignment would be impossible to get right..... I decided to pull the entire rear sub frame assembly out so I could get everything up on the bench and burn out all the seized stuff with the torch. I could then strip everything down, clean the rust off as good as I could, and paint everything. So far all the rear end pieces are clean and painted, and some of the bushings have been pressed into the arms, and some of the bushings I'm still waiting for.
Definitely turned into a bigger job than I was hoping for, and more expensive, but I think it'll be worth it in the end!
