Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 95
Thread: DIY Horn Upgrade
  1. #31
    !@#$%^&*()_+ mixmasterlove's Avatar
    Donated: $5
    Join Date
    Aug 2006
    Location
    NY
    Posts
    614
    Quote Originally Posted by RedBaron View Post
    Didn't change mine, and it hasn't blown yet (~9 months).
    Thanks for the quick reply...... I can't wait to add it !!! I got abused by my coworkers until 1 of the other guys should up in his Kia. I saw on other peoples pix that there is already a ground on the other side, how did you end up powering it and did you have to add any other wiring. Sorry for all the questions. Thanks again.
  2. #32
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,257
    I didn't mess with any fise or relay and no problems.
  3. #33
    Registered Member
    2013 CX-5 Touring FWD; 2013 BMW Z4 35i
    Join Date
    Mar 2012
    Location
    Santa Rosa, CA
    Posts
    3,383
    Quote Originally Posted by mixmasterlove View Post
    Did you bother to read the thread you posted on? Everything you need to know is detailed in the previous three pages.
  4. #34
    Registered Member
    2014->2016->2018 CX-5 AWD Touring, various Miatas
    Join Date
    Jan 2014
    Location
    Marlboro, MA
    Posts
    159
    I think I'm gonna add the high note horn like on my 2014 6 (has both a high and low). Just wondering do I have to change, or add or modify the current fuse, seeing is as its going from 1 for to 2?
    Unless you're adding an air horn with a compressor (like a Siebel Nautilus or Wolo Bad Boy) the existing circuit will be fine.
  5. #35
    Registered Member dergibog's Avatar
    Mazda CX-5 '14 GTw/Tech
    Join Date
    Feb 2013
    Location
    Arvada, Coloado
    Posts
    342
    Yeah. No need to install a circuit.
  6. #36
    Donated: $5
    Join Date
    Aug 2006
    Location
    NY
    Posts
    614
    Quote Originally Posted by paris1 View Post
    There is nothing in the posts (specifically pictures) showing how to ground and power the 2nd horn.......
  7. #37
    Registered Member RedBaron's Avatar
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    Just ground the 2nd horn to its mounting bracket. The first post shows there's already a ground point there.
  8. #38
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,257
    This may help, if you aren't sure what you aren't what you are looking at this is the ground wire. Basically you would hook the ground wire from your daisy chained (or however you made it) horns into it. Typicall you would just use another loop connector like that and bolt it against the one already there. The first is the picture eon the first page, the second two are my wiring set up. You can make something like this and test it with a 9v battery. If you get a scratching sound your circuit works. A stop at autozone or the like can get you all the shit you need to do it. The two wires are identical, but it's recommended to try to get them to the length you think you will need so you don't have excess wire to bundle/hide.
  9. #39
    Donated: $5
    Join Date
    Aug 2006
    Location
    NY
    Posts
    614
    Shout out to Chris, for PMing me and walking me through the whole process !!! Advice for anyone looking to do the mod, the oem horn wire is super thin like 18 gauge, and I used the high note horn from a 2014 Mazda 6 as the add on and it worked perfectly and the bracket even had a threaded hole to screw in existing ground.
  10. #40
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,257
    Word. I've received a lot of good help on this forum I try to give back when I can.
  11. #41
    Registered Member
    CX5
    Join Date
    May 2014
    Location
    Olinda victoria
    Posts
    3
    CX5's single horn is the same horn as the low tone (~300Hz) horn on the new Mazda 6. I bought the high tone horn for A$53 and located opposite original using those great instructions above. Sounds great. Standard fuse should be ample long term. Part number in AUS for high tone horn is GKL1-66-78YA.
  12. #42
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    Actually, I have to say that I (well, my wife anyway) would recommend against this mod.
    Scares the living crap out of her when I lock the car just after she gets out!
  13. #43
    Registered Member
    2015 Mazda CX-5
    Join Date
    May 2014
    Location
    Portland, Or
    Posts
    111
    Will the hella supertones sound different when you use the supplied relay opposed to not using the relay?
  14. #44
    Superbrowndude Superbrowndude's Avatar
    2013 CX-5 GS
    Join Date
    Oct 2011
    Location
    Stratford,on
    Posts
    54
    Why no one do train horn yet !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!11
    324Whp/372Wtq
    02 GTP @ 12 psi
    13-CX5-GS
  15. #45
    Registered Member
    cx5
    Join Date
    Aug 2014
    Location
    stanton CA
    Posts
    36
    Pretty sure that NONE of the models will (or even CAN) let you adjust the level of the horn, locking the car or otherwise. I have a touring, and there's no option for that. The horn(s) are pretty simple devices, you apply 12V, they sound off. No level adjustment possible.
    Having said all that, the short beep of the two horns is just fine when locking.
    I k ow this is old but maybe the newer models are updated. My 2015 has 3 levels of loudness. And I don't see why the h3ll they haven't updated the horn since you all made this post. Its so geeky. I'll just crash instead of trying to avoid an accident. Lol
Similar Threads
  1. Replies: 31
    Last Post: 05-01-2016, 09:03 PM
  2. DIY/ How To: Horn Replacement w/ Dual horn
    By Taus-MP5 in forum Protege5
    Last Post: 04-01-2012, 08:40 AM
  3. Low tone horn added to factory high tone horn
    By MS3Steve in forum Mazda3 Infotainment
    Last Post: 01-11-2011, 08:47 AM
  4. Hella horn upgrade
    By Rhon in forum Mazda3 General
    Last Post: 09-05-2010, 04:13 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
