So was just heading to my parents house and pulled onto the highway. Heading down the ramp I noticed my temp gauge was climbing and climbing and climbing. I backed off the gas and pulled over at the next exit. Checked under the hood and coolant res is full but it was steaming some. Didn't pop the radiator cap (car was hot). I cranked the heat and was getting HOT air and the temp gauge started to drop and settled back at normal range. Made it the rest of the way about ten miles with the windows open and the heat blasting. If I turned the heat off temps shot back up again. I'm thinking thermostat, would that be correct? I don't believe the oem one has the fail safe feature does it? Please help and soon. I'd like to be able to pick up parts tonight if needed and swap things out tomorrow am when the car is cold.
