Anyone with a CX-5 having issues where the laser unit in the Smart City Brake Support system (SCBS) sets off their Valentine One's laser detector?
I just installed my V-1 in my '14 CX-5 GT and I had to shut off the V-1 as it goes off constantly thinking there is a laser speed device nearby. Interestingly, disabling the SCBS in the multi-info display had no effect on this.
Ok, I'm having a problem inserting the fuse tap into the fuse slot. The fuse slot has these small hooks to keep the fuse in place and they prevent the fuse tap from being inserted all the way in. It just pops out if you shake it a little bit, so I think when driving on some rough road the fuse tap could just fall out. Can anyone please advise on how to deal with this? Thanks.
I have the same issue, were you able to fix the problem?
Hi Ray,
Thanks for getting back to us with the additional information. It looks like your Mazda uses the recessed housing for the low-profile fuses. If you like, we can swap your installation kit out for a normal mini fuse version. The normal mini fuse tap actually fits just fine in the low-profile fuse slot, as shown in these photos [...]
