Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Hardwiring a Valentine 1
  1. #1
    Registered Member Seminole's Avatar
    2014 CX-5 GT w/ Tech
    Join Date
    Aug 2007
    Location
    USA
    Posts
    556
    DIY: How to Hardwire a Valentine 1
    Would anyone here be interested in a "how-to" on hardwiring a V1 (or any radar detector for that matter) so the wires are hidden? I did the install on Saturday night alone so I didn't take pictures. If there is interest in it I can take it down and redo the install taking pictures along the way.
    DIY
    For the purposes of this DIY, I'll be installing a Valentine 1. *Disclaimer: I am not responsible for any damage you cause to your vehicle attempting to follow these directions*
    Items needed:
    1) Radar detector
    2) Hardwire Kit
    3) Low Profile Fuse Tap. This MUST be a tap for low profile type fuses or it will not work. (This is the one I bought: http://www.ebay.com/itm/321057689413)
    4) Tool kit
    5) 10 amp and 15 amp low profile fuses.
    Step 1
    : Place your radar detector at the top of the windshield where you want to mount it with the cable connected
    Step 2: Once you have the radar lined up, remove the radar detector and begin to slide the cable into the small gap between the headliner and the windshield. Use a screwdriver with a cloth covering the tip to help if need be:
    Step 3: Remove the A Pillar cover. You can find the instructions on the removal here on page 1,712 (https://www.dropbox.com/sh/u877jw1v4...ccessories.pdf):
    Step 4: With the cover removed, run the cable along the top of the column, making sure to not cross over the airbag (the rolled up white tube at the bottom of the column):
    Step 5: Run the cable through the opening in the cable groupings at the bottom of the pillar:
    Step 6: Run the cable down the side of the dash under the weather striping:
    Step 7: Remove the cover to the fuse box and then pull the cable into the fuse box:
    Step 8: Take a ratchet and slightly loosen the bolt located in the top left corner of the fuse box. Then take the black ground wire from the V1 hardwire kit and place it behind the bolt and re-tighten it:
    Step 9: Take the small blue clamp included in the V1 hardwire kit and close and lock it onto the fuse tap bought from eBay or your local auto part store. Insert two fuses into the fuse tap, a 15 and 10 amp fuse:
    Step 10: Snap the clamped fuse onto the connector at the end of the red cable on the hardwire unit:
    Step 11: Per the cover to the fuse box, the 3rd spot on the right hand column of fuses is for a rear outlet that CX-5's don't have. This would be where the outlet for the rear seats would be. The good thing about this outlet is that it will power on and off with the car:
    Step 12: Place the fuse tap into the empty 3rd spot with the fuses facing down:
    Step 13: Connect the cable to the hardwire unit:
    Step 14: Place the cables back into the fuse box and place the cover back on:
    Step 15: Connect your radar and turn the car on. Verify it turns on and off with the ignition and enjoy!
    Current: 2017 CX-5 GT Machine Gray
    Past: 2014 CX-5 GT w/Tech Crystal White
    Hardwired V1 - (click here for instructions: http://www.mazdas247.com/forum/showt...-a-Valentine-1)
  2. #2
    Registered Member nizzy1115's Avatar
    2013 CX-5 Sport
    Join Date
    Apr 2012
    Location
    IL
    Posts
    765
    Do you have the auto dimming mirror?
    2013 Black CX-5 Sport FWD Auto
    45% front 18% rear tints | NAV | Auto dimming homelink mirror | Polk DB351 in dash, Polk DB651 in front and rear | Door sills | OEM rubber floor mats and cargo tray | Coverking neosupreme fronts
  3. #3
    Join Date
    Aug 2007
    Location
    USA
    Posts
    556
    Quote Originally Posted by nizzy1115 View Post
    Yes, but I did a fuse tap, so this would work in any CX-5 regardless if they have a auto dimming mirror or not. I'm a bumbling idiot when it comes to two things, electrical systems and wheels, but even I could do this install on my own. No wire splicing or soldering required, it's pretty much plug and play.
  4. #4
    Join Date
    Aug 2007
    Location
    USA
    Posts
    556
    Picture of the unit installed:
  5. #5
    Registered Member
    2013 Mazda CX-5 GT AWD
    Join Date
    Jul 2012
    Location
    USA
    Posts
    2
    I would most definitely be interested in a "How To" for the V1 install. Many thanks in advance!
  6. #6
    Registered Member nXt's Avatar
    2014 CX-5 Touring FWD Tech Pkg
    Join Date
    Aug 2012
    Location
    Southern California
    Posts
    711
    Quote Originally Posted by WPF5 View Post
    I too would like a how to, which fuse to tap in the auto dimming mirrors? I'd like to put a dash cam up there.
  7. #7
    Join Date
    Aug 2007
    Location
    USA
    Posts
    556
    Bump. Added the DIY to the first post.
  8. #8
    Join Date
    Aug 2012
    Location
    Southern California
    Posts
    711
    Quote Originally Posted by Seminoles View Post
    Thanks for the write-up, but aw man, thought you tapped into the auto dimming/rain sensor/infrared laser area. Not sure how long the "car charger" for the dash cam i ordered is.
  9. #9
    Join Date
    Aug 2007
    Location
    USA
    Posts
    556
    Quote Originally Posted by nXt View Post
    Sorry! I saw over on the CX-9 forums that some guys tried to tap into the rear view mirror area but couldn't find any wires tay had enough volts to power radar detectors. Plus I think that would involve splicing wires which I don't know how to do so I didn't want to risk it.
  10. #10
    Registered Member
    Join Date
    Jul 2012
    Location
    USA
    Posts
    2
    Awesome write up. Thanks, Seminoles!
  11. #11
    Registered Member
    2014 Mazda CX 5 Grand Touring with Tech Package
    Join Date
    May 2013
    Location
    In the woods
    Posts
    12
    Actually, I installed a Passport 9800i with a visor mount and wired it to the auto compass/Homelink mirror. The only problem so far is I have to turn it on and off manually for it to operate. I am going to do some research for a wiring schematic for the mirror.
  12. #12
    Registered Member
    '13 Maxda CX-5 Touring w/ Nav & '09 MINI Cooper S
    Join Date
    Apr 2010
    Location
    Fort Myers, FL
    Posts
    61
    I think when I go to do this to my wife's CX-5 I will look for power in the overhead console and eliminate the need to run wires down to the fuse area.
  13. #13
    Registered Member
    2014 CX-5
    Join Date
    Jun 2013
    Location
    Canada
    Posts
    55
    Quote Originally Posted by yetti96 View Post
    This also seems like a better idea to me. Should be able to just tap into the sunroof power somehow..
  14. #14
    Registered Member RedBaron's Avatar
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    DANGER DANGER! WILL ROBINSON!
    Just saw this and I must point out that the way you have the fuse tap inserted, YOU ARE TAKING POWER OFF THE WRONG SIDE OF THE FUSE. Meaning you are taking voltage direct from the fuse box, and the fuse in the fuse tap is being bypassed!
    If there is another fuse in the Valentine harness, then this is OK. But even in that case you should remove the fuses from the fusetap so as not to get confused when you or someone else comes back to this at a later date.
    If there IS no other fuse, you need to remove and rotate the fusetap 180 degrees, then re-insert with the wire coming out of the left side (fuse facing UP).
  15. #15
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    990
    The way to test this is to remove the fuses from the add on tap and see if you still have power to your device. Power should have to pass through the fuse to reach the device and if the fuse is pulled the device should be dead...
Similar Threads
  1. help need instructions on hardwiring cpe standback 2
    By mike000g in forum Mazdaspeed3
    Last Post: 07-29-2011, 02:18 AM
  2. Hardwiring XM
    By mrpickles18 in forum Mazda6 Infotainment
    Last Post: 04-16-2009, 11:00 AM
  3. Hardwiring My Valentine1...
    By silverbullett in forum Protege5
    Last Post: 02-27-2007, 09:46 PM
  4. Hardwiring an ipod
    By mp3_559 in forum Mazda MP3
    Last Post: 08-29-2005, 11:59 PM
  5. Powersource for Hardwiring
    By CChris704 in forum Mazdaspeed Protege
    Last Post: 07-21-2004, 09:12 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
