Double Product Release: Mazdaspeed Passenger Side Engine Mount & Drivers Side Insert
CorkSport
2010 Mazdaspeed 3
Authorized Vendor
All Mazdas!
Its finally here!! The passenger side motor mount youve all been waiting for. If youre tired of slamming your engine into the firewall, or just want to put all of those horses you spent so much money on to the ground, the new Passenger Side Motor Mount from is exactly what youve been looking for.
CorkSport Passenger Side Motor Mount
Designed as a direct OEM replacement, the CorkSport Mazdaspeed 3 Passenger Side Motor Mount maintains OEM fitment while adding a much stronger base incorporating stiffer urethane bushings and a billet aluminum structure.
The CorkSport Advantage:
Durable Designed to withstand abuse and still provide a direct connection to the ground. With billet aluminum, performance urethane and top grade hardware, the CorkSport Passenger Side Motor Mount is built to last
Vertical Bushings Like factory to limit fore/aft movement with 80 durometer urethane for improved resistance to movement
Black anodized finish with zinc coated sleeves for a durable, lasting finish and long life.
OEM Fitment Designed as a direct OEM replacement for a worry free install
CorkSport Service and Support: Receive a 2 year warranty, full color installation instructions, all of the needed installation hardware and knowledgeable telephone support
CorkSport Mazdaspeed 3 Transmission Mount Insert
We are also pleased to announce the release of our Mazdaspeed 3 Transmission mount insert. This insert is an easy way to reinforce the stock mount and prevent driveline slack.
Constructed from high durometer polyurethane: Designed to fill in the gaps in the factory rubber motor mounts to limit the movement of the engine and transmission
Patterned after the OEM Mazda mounts for accurate fitment
With the addition of these mounts you can count on a much more direct path of your power to the ground, helping you get every ounce of performance!
As with all CorkSport products, the CorkSport Passenger Side Motor Mount and Transmission Mount Insert come with a two year limited warranty, full color instructions and CorkSport service and support. The CorkSport Performance Passenger Side Motor Mount and Transmission Mount Insert are priced at $229.99 and $35.99 respectively and can be purchased at our online catalog here:
-Derrick
Latest posts
