8mm hex. Do not get just the bit, get the hex socket like this one:
I have the above socket and it fits the female hex just fine BUT with the wrench on it hits the filter -- this is not a problem taking off the drain bolt but tightening it up a socket wrench + the hex attachment does not fit. Therefore, I have to use a regular hex wrench as a result.
I just did my oil. Make sure to put some cardboard down. Once the plug is removed the oil shoots right out. I forgot to order a drain valve so I don't have to mess with the plug anymore.
This valve fits our CX-5: http://www.quickoildrainvalve.com/ProductDetails.asp?ProductCode=F106A
Why not remove oil filiter first then drain plug. Then put in drain plug before oil filter and add oil.
Speaking of oil drain plugs what kinds/sizes of crush washers do you use?
Cause that's not how I do it and I'm stubborn as hell.
Hehe - that's a good point...I'll try that
Unfortunately that doesn't work on mine (CX-5 2013 Skyactive). The oil filter is installed above the drain pan. So removing the oil filter only removes the oil left in the filter and just a little more than that.
