quadracer1313
- mazda protege5 2003
Everything is all done except i dont know which hose on the radiator is the inlet and which is the outlet???? please help
If looking at the front of the engine, the radiator inlet as at upper right (driver's side, by rad cap)...outlet to thermostat and water pump is at the bottom left...
There's one way to check. You may want an assistant.Everything is all done except i dont know which hose on the radiator is the inlet and which is the outlet???? please help
