I will update this post later to be direct links to the docs, but for now, here is a link to some of the TSBs that are available for the SkyActiv cars.
Link to full repository
ATF-FZ_REQUIRED_FOR_SKYACTIV_DRIVE_6-SPEED_AUTOMATIC_TRANSAXLE_(1)[1].pdf
AUDIO_FUSE_(15A)_INSTALLATION_AT_PDI[1].pdf
Basic_knowledge_on_i-ELOOP[1].pdf
Battery_Used_for_i-stop_System[1].pdf
BUMPER_COVER_(OR_FASCIA)_REPAIR__REFINISHING_NOTICE[1].pdf
CARGO_COMPARTMENT_LIGHT_BULB_REPLACEMENT_CAUTION[1].pdf
Charging_System_Warning_Light_Illumination_with_DTC_P0A94_00_U3000_49[1].pdf
CHATTER_NOISE_FROM_STEERING_COLUMN_COVER[1].pdf
CHIRP_NOISE_FROM_RIGHT_REAR_AT_60_MPH_OR_MORE[1].pdf
Clicking_noise_when_opening_trunk_lid[1].pdf
CONDENSATION FOG IN FRONT AND REAR COMBINATION LIGHTS.pdf
DOOR GLASS RUN CHANNEL OUT OF POSITION.pdf
Driver Seat Cushion Warmer as Service Part.pdf
DRIVER-SIDE POWER DOOR MIRROR VIBRATION.pdf
Engine noise while driving.pdf
ENGINE START STOP PROCEDURE WITH ROOM FUSE REMOVED.pdf
ENGINE WILL NOT START WHEN USING REMOTE ENGINE STARTER (RES).pdf
EXCESSIVE CONDENSATION OR WATER WITHIN THE HEADLAMP ASSEMBLY.pdf
FRONT SEAT CUSHION COMING OFF SEAT FRAME - (CLOTH SEAT ONLY).pdf
Handling Caution for Trailer Transportation.pdf
HOOD VIBRATION WHILE DRIVING AT HIGHWAY SPEED.pdf
HORN SOUNDS BY ITSELF.pdf
How to CHECK SA-DIESEL Engine Oil Level.pdf
KNOCKING RATTLING NOISE FROM PASSENGER SEAT BACK -.pdf
LIFTGATE OPENER SWITCH INOPERATIVE.pdf
MAZDA SERVICE PROGRAM (MSP38) - ROUGH IDLE AND ENGINE STALL DURING.pdf
MAZDA SERVICE PROGRAM (MSP39) - MIL ILLUMINATION WITH DTC P012600.pdf
MIL ON WITH DTC P2610.pdf
NEW MODEL SERVICE CAUTIONS CX-5.pdf
NEW MODEL SERVICE CAUTIONS Mazda 6.pdf
PASSENGER AIRBAG DEACTIVATION (PAD) INDICATOR.pdf
POOR APPEARANCE OF GLOVE COMPARTMENT.pdf
RATTLE NOISE AT IDLE SPEED DURING ENGINE WARM UP.pdf
RATTLE NOISE FROM INSTRUMENT PANEL ANDOR CREAK NOISE FROM APILLAR.pdf
Rattle Noise from Passenger side Instrument Panel.pdf
RATTLING NOISE FROM LIFTGATE WHEN GOING OVER A BUMP.pdf
REAR CENTER SEAT BRACKET COVER COMES OFF.pdf
Rear mount camera does not operate.pdf
Right side of front bumper is lifted up from fender.pdf
ROUGH IDLE WITH MIL ON AND DTC P0015 P0524.pdf
Rough idle with MIL On with DTC P0015 _ P0524.pdf
SHIFT SHOCK.pdf
SHIFT SHOCKLONG TIME LAG WHEN SHIFTING INTO REVERSE.pdf
SQUEAK NOISE FROM ENGINE COMPARTMENT.pdf
STAINS FOUND ON PAINT DURING PDI.pdf
STEERING SHIMMY OR SHAKE AT 50 - 80 MPH.pdf
TAPPING NOISE COMING FROM FRONT SEAT BACK.pdf
TAPPING NOISE WHERE EDGE OF DASHBOARD MEETS WINDSHIELD.pdf
TIRE PRESSURE MONITORING SYSTEM (TPMS) INITIALIZATION PROCESS.pdf
Tire Pressure Monitoring System (TPMS) Warning Light Illuminating Unintentionally (Mis-use Preve.pdf
TIRE PRESSURE MONITORING SYSTEM (TPMS) WARNING LIGHT ILLUMINATION.pdf
TOMTOM NAVIGATION SYSTEM SERVICE INFORMATION.pdf
UNABLE TO LOWER REAR SEATBACK WITH REMOTE HANDLE SEATS HARD.pdf
UNUSUAL ENGINE NOISE AFTER A COLD ENGINE START.pdf
Whining sound from the engine compartment after starting a cold engine.pdf
Wind Noise from Rear Door while driving at 40 km_h.pdf
Wrong indication i-ELOOP gauge when driving with auto cruise ON.pdf
Thanks to SayNoToPistons for the docs!
SHIFT SHOCK.pdf
