Page 1 of 17 12311 ... LastLast
Results 1 to 15 of 241
Thread: SkyActiv TSBs (Technical Service Bulletins)
  1. #1
    meh wannabe's Avatar
    16 CX-5, Old: 06 Mazdaspeed6, 08 CX-7, 01 Protege ES/Mp3wannabe
    Join Date
    Feb 2003
    Location
    Painesville Twp, Ohio
    Posts
    4,467
    I will update this post later to be direct links to the docs, but for now, here is a link to some of the TSBs that are available for the SkyActiv cars.
    Link to full repository
    ATF-FZ_REQUIRED_FOR_SKYACTIV_DRIVE_6-SPEED_AUTOMATIC_TRANSAXLE_(1)[1].pdf
    AUDIO_FUSE_(15A)_INSTALLATION_AT_PDI[1].pdf
    Basic_knowledge_on_i-ELOOP[1].pdf
    Battery_Used_for_i-stop_System[1].pdf
    BUMPER_COVER_(OR_FASCIA)_REPAIR__REFINISHING_NOTIC E[1].pdf
    CARGO_COMPARTMENT_LIGHT_BULB_REPLACEMENT_CAUTION[1].pdf
    Charging_System_Warning_Light_Illumination_with_DT C_P0A94_00_U3000_49[1].pdf
    CHATTER_NOISE_FROM_STEERING_COLUMN_COVER[1].pdf
    CHIRP_NOISE_FROM_RIGHT_REAR_AT_60_MPH_OR_MORE[1].pdf
    Clicking_noise_when_opening_trunk_lid[1].pdf
    CONDENSATION FOG IN FRONT AND REAR COMBINATION LIGHTS.pdf
    DOOR GLASS RUN CHANNEL OUT OF POSITION.pdf
    Driver Seat Cushion Warmer as Service Part.pdf
    DRIVER-SIDE POWER DOOR MIRROR VIBRATION.pdf
    Engine noise while driving.pdf
    ENGINE START STOP PROCEDURE WITH ROOM FUSE REMOVED.pdf
    ENGINE WILL NOT START WHEN USING REMOTE ENGINE STARTER (RES).pdf
    EXCESSIVE CONDENSATION OR WATER WITHIN THE HEADLAMP ASSEMBLY.pdf
    FRONT SEAT CUSHION COMING OFF SEAT FRAME - (CLOTH SEAT ONLY).pdf
    Handling Caution for Trailer Transportation.pdf
    HOOD VIBRATION WHILE DRIVING AT HIGHWAY SPEED.pdf
    HORN SOUNDS BY ITSELF.pdf
    How to CHECK SA-DIESEL Engine Oil Level.pdf
    KNOCKING RATTLING NOISE FROM PASSENGER SEAT BACK -.pdf
    LIFTGATE OPENER SWITCH INOPERATIVE.pdf
    MAZDA SERVICE PROGRAM (MSP38) - ROUGH IDLE AND ENGINE STALL DURING.pdf
    MAZDA SERVICE PROGRAM (MSP39) - MIL ILLUMINATION WITH DTC P012600.pdf
    MIL ON WITH DTC P2610.pdf
    NEW MODEL SERVICE CAUTIONS CX-5.pdf
    NEW MODEL SERVICE CAUTIONS Mazda 6.pdf
    PASSENGER AIRBAG DEACTIVATION (PAD) INDICATOR.pdf
    POOR APPEARANCE OF GLOVE COMPARTMENT.pdf
    RATTLE NOISE AT IDLE SPEED DURING ENGINE WARM UP.pdf
    RATTLE NOISE FROM INSTRUMENT PANEL ANDOR CREAK NOISE FROM APILLAR.pdf
    Rattle Noise from Passenger side Instrument Panel.pdf
    RATTLING NOISE FROM LIFTGATE WHEN GOING OVER A BUMP.pdf
    REAR CENTER SEAT BRACKET COVER COMES OFF.pdf
    Rear mount camera does not operate.pdf
    Right side of front bumper is lifted up from fender.pdf
    ROUGH IDLE WITH MIL ON AND DTC P0015 P0524.pdf
    Rough idle with MIL On with DTC P0015 _ P0524.pdf
    SHIFT SHOCK.pdf
    SHIFT SHOCKLONG TIME LAG WHEN SHIFTING INTO REVERSE.pdf
    SQUEAK NOISE FROM ENGINE COMPARTMENT.pdf
    STAINS FOUND ON PAINT DURING PDI.pdf
    STEERING SHIMMY OR SHAKE AT 50 - 80 MPH.pdf
    TAPPING NOISE COMING FROM FRONT SEAT BACK.pdf
    TAPPING NOISE WHERE EDGE OF DASHBOARD MEETS WINDSHIELD.pdf
    TIRE PRESSURE MONITORING SYSTEM (TPMS) INITIALIZATION PROCESS.pdf
    Tire Pressure Monitoring System (TPMS) Warning Light Illuminating Unintentionally (Mis-use Preve.pdf
    TIRE PRESSURE MONITORING SYSTEM (TPMS) WARNING LIGHT ILLUMINATION.pdf
    TOMTOM NAVIGATION SYSTEM SERVICE INFORMATION.pdf
    UNABLE TO LOWER REAR SEATBACK WITH REMOTE HANDLE SEATS HARD.pdf
    UNUSUAL ENGINE NOISE AFTER A COLD ENGINE START.pdf
    Whining sound from the engine compartment after starting a cold engine.pdf
    Wind Noise from Rear Door while driving at 40 km_h.pdf
    Wrong indication i-ELOOP gauge when driving with auto cruise ON.pdf
    Thanks to SayNoToPistons for the docs!
    2016 Deep Crystal Blue CX-5 Grand Touring AWD - 2016 Subaru WRX Limited
  2. #2
    Wheels, not rims... SayNoToPistons's Avatar
    CX-5 GT AWD w/ Tech, RX-8 GT 6spd w/ 'goodies'
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,773
    Sorry for the slow response. The rest will be uploaded tonight.
    Thank you wannabe for helping share the documents with the community.
    EDIT:
    THE TSB'S PROVIDED ARE NOT ONLY FOR THE CX-5 SA-G. ALL SKYACTIV PLATFORMS OF MAZDA ARE NOW UPLOADED
    2013 Mazda CX-5 Daily - GT, Tech Pack, AWD, Black Mica, Sand/White Interior, LED everrrryyything, Morimoto XB LED Foglights
    2004 Mazda RX-8 Driveway/AutoX Queen - KW Varient 3 Coilovers, Cobb AP + Tune, Progress Tech Sway Bars, Enkei RPF1 + RE11 in 275, Greddy Evo TT Catback, BHR catless midpipe, BHR coils, BHR motor mounts, Racing Beat intake snorkel, AF Short Throw Shifter, etc etc.
  3. #3
    Registered Member jb's2014CX5's Avatar
    Mazda CX5 GT AWD 2014
    Join Date
    Mar 2013
    Location
    Worcester, Ma
    Posts
    79
    Thanks for listing these I found one that needs to be done to my cx5
  4. #4
    Registered Member
    2014 Mazda CX-5 GT w/Tech PKG JBM
    Join Date
    Jun 2012
    Location
    Atlanta, GA
    Posts
    200
    Thank you guys for putting up the TSB's!
  5. #5
    Registered Member kampfire's Avatar
    2013 CX-5 Touring FWD w/ Tech Package
    Join Date
    Jan 2012
    Location
    Michigan
    Posts
    112
    awesome work. thanks!
    Mine: 2011 VW GTI
    Wife's: 2013 Mazda CX-5 FWD Touring w/ Tech package
  6. #6
    Registered Member Jonesey's Avatar
    CX-5 6MT
    Join Date
    May 2012
    Location
    NJ
    Posts
    138
    Thanks!
    I may have the RATTLING NOISE FROM LIFTGATE WHEN GOING OVER A BUMP....
  7. #7
    Registered Member Jcanracer's Avatar
    CX5 Sport 6spd
    Join Date
    Jun 2012
    Location
    South Florida
    Posts
    273
    Finally! The TSB(s) I needed! I love you guys.
  8. #8
    Registered Member CX-SV's Avatar
    Donated: $15
    2013 CX-5 GT AWD w/tech (Mar'12-Jul'14)
    Join Date
    Apr 2012
    Location
    northern CA
    Posts
    3,410
    Great listing of TSB's. Excellent effort by SayNoToPistons, much appreciated.
    I especially like the TSB on Engine Noise After a Cold Start, finally a complete explanation of what causes the noise and why.
  9. #9
    Registered Member
    2013 Mazda CX-5 Touring Zeal Red/Moonroof pkg
    Join Date
    May 2012
    Location
    CA
    Posts
    71
    Thank you so much, these are very important information!
  10. #10
    Registered Member stromdriver's Avatar
    Mazda CX-5 Touring w/bose-tech
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    ugh can't wait to shove these in teh face of the dealer, they've been claiming they dont know of any tsbs for the cx5 and dont have any in their computers....
  11. #11
    Donated: $15
    Join Date
    Apr 2012
    Location
    northern CA
    Posts
    3,410
    ^ Need to consider going to a better (less lethargic and lazy) service writer. My Mazda service writer doesn't claim ignorance.
  12. #12
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    there was a guy there as service manager who was pretty good/helpful, but they moved him to a different brand (its a big automall type place)
  13. #13
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,773
    One of the major reasons why I pushed to have these given to the general consumers.
  14. #14
    Registered Member ZiaCX-5's Avatar
    2014 CX-5 Grand Touring FWD
    Join Date
    Apr 2013
    Location
    New Mexico
    Posts
    23
    I have a 2014 and have both the hood shake and left outside mirror shake. The dealer I purchased the car from is 200 miles away. We emailed about an appointment for some paint chips that were in the car when I purchased it, as we had agreed they would fix them the next time I was in town; and I notified them of my concern and they said they would check into it. I gave them the TSB numbers and asked them if they would address the issues when I left the CX-5 with them all day and overnight. They came up with all kinds of excuses. They don't know why the mirror would shake so they are supposed to order another housing unit or something for that. As far as the hood shake. They said all the 2014's do that. And since the TSB's were for other years or VIN numbers mine should be fine. Needless to say I will never take my car back to these jerks. I will be e-mailing the owner of the lot. It is supposed to be a "family" owned business but I doubt anything will happen. It's disappointing but I am not going to let it ruin me on Mazda as a whole.
  15. #15
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,773
    That is a good mindset. There are many dealers across the country that give Mazda a bad rep as a whole. Unfortunately MNAO hasn't done much in terms of locking down on these half-assed dealers. Definitely try another dealer, and if they refuse, say you will make their refusal to look into the problem turn into a problem with corporate.
Similar Threads
  1. CX-7 TSB (Technical Service Bulletins)
    By Shaz in forum Mazda CX-7
    Last Post: 07-29-2014, 03:24 PM
  2. Replies: 2
    Last Post: 01-04-2014, 10:22 AM
  3. Replies: 0
    Last Post: 03-28-2013, 07:25 AM
  4. Technical Service Bulletins
    By CXRabbit in forum Mazda CX-7
    Last Post: 12-26-2006, 04:05 PM
  5. Technical Service Bulletins
    By Jim Frye in forum Protege5
    Last Post: 01-17-2003, 02:29 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
